Home > Technical (L322) > Gearbox broke ?!
Page 1 of 3 123>
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Gearbox broke ?!
My TD6 just ground to a halt whilst manoeuvring slowly. Rumbling noises and low gear symbol lighting up. Won't move forwards or backwards. I suspect is the gearbox (103,000 miles). RAC on their way so I suspect it may be best to have it recovered to a gearbox specialist. Chester auto transmissions is only about 10 miles away. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #143787 30th Sep 2012 3:18pm
Sorry to hear it Mikeyjd - happens to all the good people !
Mine did the same three years ago. Guess you need to be looking for sonnax valves as a part of the rebuild then you can go on forever! .
Post #143804 30th Sep 2012 6:45pm
Mikeyjd
While I was waiting for RAC after half an hour I started the car and it drove perfectly for about 20 yards then stopped. Rattle noise in drive or reverse and no movement. RAC didn't send a man to look at it, just a low loader, they obviously suspect broken gearbox after my phone explanation. Will be stored overnight by the recovery company and taken to gearbox repairers in morning.
I have been half waiting for the gearbox to go, over the last few months just because of the mileage, although when it finally went I didn't get any warning. Luckily I was at my in-laws at the time not far away, so it wasn't any real inconvenience. In a way I am glad, I was planning on a longish drive on Tuesday and could have been stranded miles away.
Better raid my piggy bank Sad No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #143807 30th Sep 2012 7:35pm
mjdronfield
Let us know how you get on if you ask about the sonnax valve blocks...........
I've emailed a few suppliers this weekend and await a reply / prices..........
http://www.fullfatrr.com/forum/topic13781.html
Good luck. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #143825 30th Sep 2012 9:12pm
Get the valve body above and also get the box fully cleaned out and the tc sent to mackies in glasgee.
While the box is out get th clutch packs checked as well, better to be done now! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #143840 30th Sep 2012 10:14pm
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
Do you mean the 'Low Range' light came up when you say 'low gear symbol'? If so, it could be the transfer case and not the gearbox. Do you get "TRANS FAILSAFE" come up?
I would check the TC as well - much cheaper fix than the Trannie.
Cheers - Gav
Post #143857 1st Oct 2012 6:03am
mercs600
England 2002 Range Rover Vogue Td6 Java Black
For future use I wouldn't mind getting a Sonax - as when it finally lets go I can give it to the gearbox specialist to fit at the same time ! Does anyone have any prices for one here in the UK ? Wink
Post #143878 1st Oct 2012 9:10am
mjdronfield
Literally in the last few mins I've received an email from Mackie transmissions.
They fit the Sonnax upgrade and offer a lifetime warranty on the torque converter.......
Seems like a top job to me........
"The cost to recondition both transmission & torque converter is £1850.00+vat,
We fully recondition your transmission & torque converter to manufacturers specifications including the sonnax valve/body upgrade and all this is done here at our premises mark,
We recondition your torque converter in house and it has a life time warranty,
Yes mark you need to replace the transmission oil cooler 100% as the fine metal lodges inside and it is impossible to get it all out, so best to replace it,
Hope this helps you to decide mark". 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #143880 1st Oct 2012 9:14am
Does this price include removing and refitting the box?
Post #143883 1st Oct 2012 9:27am
mjdronfield
I did assume you had to ship your transmission to them, and they shipped it back.
Could be wrong.
I'll email back and double check........ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #143887 1st Oct 2012 9:35am
mjdronfield
Just got another email.
Its a bit more expensive if they remove and refit from the car.
Now I'm confused with the lifetime warranty on the TC that was mentioned earlier ;
"Sorry I forgot to mention in my e-mail that if we do the complete job at a cost of £2642.63+ vat it comes with a three year warranty (parts and labour), if we supply the exchange transmission only then it has a 1 year warranty on the transmission & torque converter only". 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #143900 1st Oct 2012 10:48am
So to recondition your own box is £2220.00
For them to do the complete job is £3171.15 Does this include the cooler?
Almost £1000 for them to remove and replace the box and fill it with fluid Shocked
Well if it's anything like the Lifetime warranties we hear about then the warranty runs out when it stops working as the lifetime has just expired and the TC is at the end of its life Big Cry
Post #143910 1st Oct 2012 11:28am
mjdronfield
Thats my understanding.
As they are in Glasgow, its unlikely I'll take the car up there.
More likely to have the gearbox shipped up once removed.
Didn't think £2200 was too bad inc the Sonnax upgrade.
They may well do the oil cooler as part of the complete job.
How long does it take to remove and refit a gearbox ?
Can't see it costing £1000, but I'm not a mechanic....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #143921 1st Oct 2012 11:42am
You need the right equipment to remove the gearbox, it will be a heavy brute...
I would think about 2-3 hours to remove and 3-4 hours to replace
Post #143924 1st Oct 2012 11:46am
mjdronfield
Sorry Mikeyjd, seem to have taken over your thread with my email correspondence.
I hope it may be of use to you........ Smile
Just got this back from an email at automaticgearboxes.co.uk........
"I received your enquiry from Matt at Sussex Autoparts. We specialise in the GM5L40E range of transmissions they are upgraded with modified
parts in the valve body and oil pump from Sonix.
Once these units are rebuilt they are then tested on our dyno machine for 25 minutes this ensures the vehicle shifts correctly and has no leaks or noises.
Our warranty is 12 months, 12,00 miles which ever is the sooner and is delivered fully packaged together with fitting instructions and kooler flush, the costs for this is £1495 inc torque converter, there will be a surcharge of £500 which is reimbursed once we have the old unit back and delivery and collection is £80 all plus vat. A fitting service is available if requested.
Regards"
So if we ignore Paul's typos, thats £1794 inc VAT for a gearbox with the Sonnax upgrade. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #143931 1st Oct 2012 12:27pm
Page 1 of 3 123>
