![]() | Home > Technical (L322) > Where is the fuse box |
There is a big black box on (your) drivers side under the hood. It is just behind the headlight next to the wheel arch. It has a big cover on top that is screwed down with torx screws. In their you have the gear box ECU, transfer box ECU and a bunch of fuses, relays and connectors. It is very easy to get to and work on.
lesmcm Member Since: 12 Jul 2010 Location: Aberdeen Eastern Cape Posts: 30 ![]() ![]() ![]() |
Thanks
