![]() | Home > Technical (L322) > Gearbox broke ?! |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7979 ![]() ![]() ![]() |
Cool.
Ashcroft Transmissions don't do the gearboxes on the Td6, but passed me on to another company called Signature Transmissions Ltd who sent me the following ;
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
Ok, latest from the garage. The front near side driveshaft has broken. This aparantly would give the symptoms as shown I am told. (can anyone confirm that?). The garage is investigating the reason for that breakage before they can check how the gearbox is. Will phone them later today for more news. No longer FF owner but still interested. Present car Jaguar XE
HTF can a driveshaft break?!!! |
My thoughts too. That is why they want to fid out the reason before they go on to look at the gearbox. It is a bit worrying though. They didn't actually say what was the problem in much detail, maybe it's a linkage or joint or something. No longer FF owner but still interested. Present car Jaguar XE
The splines could have stripped on the end ?
If the CV joint has broken away it can only be caused by something moving enough to allow it to pop out. It could be caused by anything from a faulty suspension joint to an engine mounting. Further investigation required |
Latest news. I'm not very technically minded but the description seems to be as follows. Near side front driveshaft has an inner and outer shaft (I assume to allow change in length), the inner shaft is turning independently from the outer, so whatever locates the shaft in place (splines maybe) seems to be broken. Repair shop are in the process of pricing up a replacement. It isn't possible to check the gearbox until shaft has been replaced! I'm not holding my breath |
Sounds like a front diff problem to me |
Right I have done reading up. The drive shaft is made up of a solid shaft which goes into a cv joint attached to the diff. There is an outer tube which goes into a cv joint at the wheel end. The inner shaft slides into the outer tube to allow changes in length. I don't know what exactly attaches the tube and shaft to allow them to turn together whilst still sliding in and out (splines maybe), there is also a ball race fitted inside the tube. In my case it seems the outer tube is turning independently of the inner shaft.
This is the driveshaft, No.1 end goes into the diff, No. 3 through the hub.
Section 47-3 of the service manual shows a cross section diagram of the components. The part marked 2 in that last picture is a hollow tube, The shaft that goes into the diff CV joint slides in and out of it. I don't know what the problem is but at he end of the day it's not working. |
Just had a call from the garage. New drive shaft fitted and the car runs fine. So, fortunately it seems the gearbox has a few miles left in it (fingers crossed). No longer FF owner but still interested. Present car Jaguar XE
Bit of a result then.
