Home > Technical (L322) > Now I can see the difference in wheel nuts!
Andy
The ones that I had with the 20" 7 spokes won't touch my studs at all. The hole is too small, so I've had to use my existing nuts (See my other post)
I have no idea what they are off, but they ain't for a ffrr! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #14420 6th Mar 2010 7:50pm
StevieH
Please everybody check the hole diameter on the wheels you have, pre 2006 is 20mm, post 2006 is23 mm. That's the only difference , thread and depth remained the same. ....Black nuts have 20mm shank and silver nuts are 23mm shank...beware the nugget who fitted 2006 RRS wheels to my FFRR painted the black nuts silver!!!!!!!
Post #14441 7th Mar 2010 2:03am
scotty7
Scotland 2003 Range Rover Vogue Td6 Buckingham Blue
just had the same problem,
change my 20" wheel for 19"s, and the wheel nuts were the wrong ones for the 20"s.
i have notice a big difference with the correct wheel nut, i always had a bit of steering wobble and the nuts needed tighning regularly.
again it has been some nugget before i got the car changing to bigger and newer wheels and using the old nuts.
cheers scotty
Post #14473 7th Mar 2010 8:51pm
Andy
Does anyone know what these wheel nuts are for that I've been sent? The internal diameter (threaded bit) is too small for my studs. I've read somewhere that the stud thread is 14x1.5 - If thats the case, I haven't got a clue what these nuts are for! If I offer one up to the 20" rim, it rattles about in the hole and when viewed from inside, it doesn't even run the length of the hole? Yet the original black one fits perfectly, both width and length. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #14492 8th Mar 2010 9:09am
