![]() | Home > Maintenance & Mods (L322) > Problem with Headlights |
Firstly I take it you have a face lifted front...if so that’s why the adaptive lights dont work...the 05 did not have adaptive headlights so the dealer that replaced the LCM should have known this...
stirling Member Since: 18 May 2011 Location: Isle of Wight Posts: 7 ![]() ![]() ![]() |
Thanks for the reply Daveo. It is indeed a face lifted front. The lights not being adaptive I'll be taking up with the dealer as they've charged me for investigation. When it's not working with lights on I don't get any main bean at all; main units and inners. When they flash on their own accord I'm pretty sure it's just inners and I don't hear the clonking. |
True bi-xenon’s have a flap inside the xenon part of the headlamp main beam and when you flash your high beam the flap jumps up allowing your main beam pattern to go high and gives high beam, at the same time your high beam lamps on the inner part will work as well, these are only halogen, do you still have the halogen bulbs in there or have they been replaced with LED bulbs.
The inners are hologen. Last couple of months they've been playing up, no problems for over a year previously. The random uncommanded flashing can occur with the headlights on or off. With lights off, when working, only the inners flash when commanded, with headlights on more often than not I can't get full beam, occasionally can - the xenons go to full beam at which point the inners come on too. |
i would start at the relay, then on to the stalk, if driving at night do you see the blue hi-beam light on your dash flash or flicker V8 facelift Range Rover Autobiography 22" wheels.
Really appreciate your help daveo, thank you. Yes the blue dash light flickers/flashes. |
does it do it when your driving or will it do while you are stationary...how does the stalk fill, may be take the cowlin of and have a look, give the relay a few taps with a driver and see if it makes your lights flash,now i am not sure if there is a relay for the left and right side but if there is and both lights flash then i would say its unlikely its the relay. V8 facelift Range Rover Autobiography 22" wheels.
Both. The stalk feels fine but worth a look. D'you know where the relay is? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16342 ![]() ![]() ![]() |
Hi, worth looking at the stalk first but often change the LCM/BCM when this fault appears...
Thanks for your help chaps. |
