![]() | Home > Technical (L322) > Help needed understanding fault codes. |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8001
I take it you have a Td6 ?
| Stuart's the man Member Since: 16 May 2012 Location: Glasgow Posts: 94 |
Yes meant to say td6 2004 model, no smoke whatever, sometimes it will go for 10 miles with no problem, other times 1 mile.
don't think it causes them directly, but does cause smoke and allow oil to go where it shouldn't if blocked....... may cause you a red herring if you did have smoke........ 2011 Range Rover Vogue SE 4.4 TDV8
Going to get a leak off test done tomorrow to see if it shows up any problems, don't really want to pay 25 per injector for testing them |
| dogswick Member Since: 14 Jan 2012 Location: ever sunny yorkshire Posts: 20
had some leak off issues with 2 of my injectors earlier in the year, didn't cause misfires but did cause really difficult starting especially when hot.
Mine starts fine except for a couple of seconds in the morning when it sounds as if its running on 4 or 5 |
| Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 746
I had a missfire on mine, also judder when creeping forward with foot on the brake. I also came up with the fault "engine stability controller" turned out to be 2 faulty injectors ... replaced them, and it's been perfect ever since |
Did you get a leak test done to work out which ones , or did you take them all out for checking |
I took them all out to be tested, two were found to be faulty. |
For updates, see article under td6 missfire under maint and mods |
| All times are GMT |
