![]() | Home > eBay & Bargain Spots > Cat D |
DavidC Member Since: 08 Oct 2012 Location: Beds Posts: 66 ![]() ![]() ![]() |
Hi
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
found this via googling,
That cannot be CAT D |
RRV Member Since: 05 Oct 2009 Location: Midlands Posts: 648 ![]() ![]() ![]() |
It is if the assessor "knows you" |
Thanks for replies.
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
A bit of T-Cut and it will be as right as rain... |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7980 ![]() ![]() ![]() |
So if you buy the bodyshell they have, you will be talking £11390 without doing any work.....and the painting......... and it will still be a Cat D (?) so I say buy a Td6 or spend what it would have cost you nearly anyway, on a higher mileage TdV8, and at least sleep at night !! 2011 Range Rover Vogue SE 4.4 TDV8
Stuart's the man Member Since: 16 May 2012 Location: Glasgow Posts: 94 ![]() |
Noticed this going on for a long time, cat c the ones that need to be checked are light damaged, whereas the cat d which does not need to be checked are mangled, ideal for stealing someone's pride and joy and ringing it onto the plates, and never needs checked. WTF |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16394 ![]() ![]() ![]() |
The trouble with Cat C&D cars is that alot of insurance companies decide the CATing outcome is somehow linked to the size of their loss!
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
Our Golf Tdi was declared a Cat C last year after a collision with a small truck. To look at it, it looked fine. Front end was pushed over very slightly as the truck drove across the front of it, pulling the car sideways. the only way you could tell was by the gaps down the sides of the bonnet. No panels damaged apart from the bumper. Shame as it was a good car and we'd had it years.
