| | replacing pcv hoses and valve cover gaskets |  |
 im replacing the pcv hoses, valve cover gaskets and timing cover gaskets - what else should i replace whilst being busy towards the back end of the engine?
 should i replace the following:
 - radiator hoses, including O-rings both manifold to large tube and small tube, rear water return hose to heater
 - camshaft variable timing solenoid
 - intake manifold rear end plate
 - what else?
 is it necessary to replace the rear end cover of the intake manifold or only the gasket.
