Home > Technical (L322) > FBH Problem time
FBH Problem time
This morning it was a bit on the icy side when taking the dogs out , so thought i would hit the remote and fire up the FBH as i do the school run at 7.30 am , pressed the remote Green then flashing Green FBH kicked in then about 60 seconds later it stopped , tried again and just got the same scenario , looks like its a trip to the dealers for this i think ……..
Why do these Censored's always cause problems Rolling Eyes Rolling Eyes ====================================
Post #145468 9th Oct 2012 8:53am
ebajema
The FBH doesn't like the Scottish weather anymore than you do ??? MY 2010 5.0 SC Galway green and sand interior!!
Post #145478 9th Oct 2012 9:12am
SteveMFr
Site Sponsor
Re: FBH Problem time
Cause it's a LR? Laughing Wait - is this a trick question?.. Shocked
Rolling with laughter
Actually, the FBHs are relatively reliable (they're German made.. Whistle ). You might've just had a bit of bad luck...
Have a read at this, Mick. Wrote this in response to an FBH thread below but it basically answers your question. BTW, JR has kindly let me know tha my old info on FBHs is... old. The flame sensor is no longer a photocell, rather resistance is measured at the glow plug. All other info is correct, tho.
If you'd a bought an IIDTool, it would now tell you what is bad... Cool
JK - I hate pressure selling tactics
SteveMFr wrote:
JR's info is spot on.
The ignition sequence for the FBH is (exactly the same as an oil furnace, btw):
- glow plug pre-heat ~30sec. > fuel pump on ~5sec > combustion air fan on > flame sensor must detect a flame w/in ~5-10 sec or it automatically shuts down.
These times are very approximate and stem from when I used to work on these things over 15 years ago. I'm sure there is a service manual for the FBH floating around the net somewhere. There will be an accurate time line printed in that.
You can hear each of these steps (except for the glow plug heating, obviously :-p ): about 30 secs after the FBH is told to start the fuel pump can be heard ticking quietly (rear seat), and then the combustion air blower begins to whir (behind the RF wheel). If the FBH ignites, the whir will grow to a small jet-engine like sound.
The FBH is a very simple device and really does function just like a small oil furnace only that the fuel is not injected but rather metered exactly on to a membrane. The combustion air fan (or blower) also has to blow an exact volume of air through the membrane so that the mixture is correct. The glow plug ignites the mixture and the flame sensor (a simple photo cell) must report the presence of a flame w/in a certain time or the FBH shuts down as a precautionary measure before the fuel pump fills the FBH with unburnt fuel. Both the fuel pump and the combustion air fan are designed to meter the fuel / air exactly when the receive 12V and are otherwise more or less 'sealed units'. If they do not function properly, they must be replaced.
The most likely culprits in a failed ignition sequence are (from most to least likely):
- bad glow plug
- bad flame sensor (in this case you'd hear the FBH ignite as described above but it would then suddenly shut down)
- bad fuel pump (no fuel/too little fuel)
- bad combustion air fan (no air/too little air)
As my experience is based on working on FBH's in general and I have no experience working on exactly the FBH's in our RR's, I can not tell you how sensitive the ECU's are and how far up the likelihood ladder they should be placed. I can tell you that based on my experiences on working with auto electrics/electronics, ECU's are replaced far more often than necessary by technicians inexperienced on that particular vehicle system.
As the IIDTool is giving you a flame sensor fault, listen to the ignition sequence. If you can hear the whir grow to a (very small Razz ) roar after a couple of seconds and the FBH then still shuts down, this will be your prob. A new flame detector should not cost more than GBP20-25 max. The only other alternatives at that point would be the ECU or an even more rare wiring prob (short to ground in the flame detector wiring).
Please let us know what happens.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #145698 9th Oct 2012 10:33pm
Man up biscuitbaws, wasn't even that cold this morning Whistle
Post #145708 10th Oct 2012 12:15am
Tried to fire mine up at the weekend Mick,
didnt work on the saturday, but after a few goes it fired up on sunday and is now firing up fine. Maybe they just need a bit of regular use.
Run a few stop start cycles and see if it lights. Mine was definately going as the flue gasses under the car were warm
Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #145721 10th Oct 2012 7:22am
mzplcg
47p2 wrote:
Man up biscuitbaws
Rolling with laughter Rolling with laughter
Love that expression. A Glasgow lad used to work for me and there were quite a few variations on the "Baws" word, depending on the circumstances. Still PMSL recalling some of those.
Oh, you're right too. Man up Mick. You lads from Scotland aren't supposed to feel the cold. Even Rab C Nesbitt only ever wore a string vest Laughing
Post #145722 10th Oct 2012 7:35am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Must be something in the air up here as mine won't fire up.
Car going in next week for warranty work so another one to add to the list.
Ian
Post #145724 10th Oct 2012 7:51am
Although we are only 8 miles apart up here in EK can be entirely different to your area on cold mornings bawbag ,
Anyhow it wasn't for me it was to try and heat the car up for the school run ya heidnipper Laughing Laughing ====================================
Post #145732 10th Oct 2012 8:46am
Oh so toasty warm in my garage this morning fannybaws Whistle
Post #145743 10th Oct 2012 9:48am
wackyjim
Scotland 2011 Range Rover SE TDV8 Santorini Black
U west coast boys dinnae ken what cauld is!!!..up here in the north east when the wind starts soochin thats real cauld weather!! Laughing by the way my FBH is no working either Big Cry
Post #145745 10th Oct 2012 9:57am
Surprised you haven't posted pictures up of your oh so wonderful garage as you normally do ya glaikit looking botten … Yawn Rolling with laughter ====================================
Post #145746 10th Oct 2012 9:58am
Looks like this when I open the door and the heat escapes ya dobber Laughing Laughing
Post #145749 10th Oct 2012 10:09am
That because you're not allowed to fart in the Hoose ya eejit Laughing Laughing ====================================
Post #145750 10th Oct 2012 10:13am
Posh people don't fart ya fud Whistle
Post #145755 10th Oct 2012 10:31am
And how would you know that , you are just a Weegie that has moved into an area where all the old folk in Glasgow go to die and think they are snobs … Laughing ====================================
Post #145758 10th Oct 2012 10:35am
