Home > Maintenance & Mods (L322) > Brake caliper sticking
Page 2 of 3 <123>
ikilla2
2003 Range Rover HSE Td6 Stornoway Grey
Did In see somewhere, someone said Disco3 rear callipers are a direct bolt on?
Post #144724 4th Oct 2012 7:39pm
How much brake fluid is req for a system change? Also will any DOT4 brake fluid surfice? Would halfords own be ok or do we need something more exotic? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #145866 10th Oct 2012 7:42pm
Any DOT4 will be fine. how much depends on how much you pump through. I would have thought 1 litre should be plenty
Post #145869 10th Oct 2012 8:06pm
What's the best way of doing it? Pump until clean ish fluid comes through each corner, making sure the reservoir doesn't go below the min mark? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #145871 10th Oct 2012 8:27pm
Gunson Eezibleed Thumbs Up
Post #145876 10th Oct 2012 8:52pm
That looks good but has spongy brakes written all over it! Whistle [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #145880 10th Oct 2012 9:17pm
I always thought they would be a load of crap, but I bled my brakes with one earlier this year when I changed the calipers and when I went for my MOT the tester couldn't believe the pressure at the wheels
Awesome bit of kit and highly recommended Thumbs Up
Post #145885 10th Oct 2012 9:41pm
Caliper changed today. Took all of 30mins and a simple job. Bled the brakes and flushed through each corner. Used about 1.5L of brake fluid. The new fluid is a nice dark honey colour but the old stuff is really dark. I'm not sure if it changes with age but it didn't look to nice. Will be giving it another flush in a weeks time just to be sure. Can't really feel much difference in the brake pedal but the work for cant complain. I've always been able to push the peddle to the floor which is still there but this would cause a massive lock up if the ABS didn't cut in. If anyone's I retested will post some pics of old and new fluid? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #146507 15th Oct 2012 7:49pm
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
just like to bring this thread back to life...
a few guys mentioning they have bought / exchanged reconditioned calipers, but ive had a look on goggle and could not find any for less than £190.
could anyone point me in the correct direction please? MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #161860 4th Jan 2013 3:24pm
Euro Car parts.
Look for the pagid ones and at the checkout use PAGID30 as the voucher code. They surcharge £24 ontop and refund this when you send yours back in or drop at back at their nearest depot which to be fair is more than what you would get for it on ebay in its current state Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #161861 4th Jan 2013 3:31pm
woodchopper23
166 pounds including a surcharge of 54 pounds..... Still considerable more than the figures quoted earlier in the thread. I'm just going to ender the discound code and see what that does Thumbs Up king pleb MY2010 TDV8 Vogue Ipanema Sand
Post #161878 4th Jan 2013 4:46pm
woodchopper23
Pagid30 unfortunatly doesn't work any longer it seems. That's for the input though , at least I've found euro car parts who stock them and are still considerably cheaper that other sites I have seen sofar. MY2010 TDV8 Vogue Ipanema Sand
Post #161880 4th Jan 2013 4:49pm
Worked for me Wink Are you trying it on a PAGID caliper though and not an eibach thing?
Also is this for a rear caliper?
Try PARTS25 as well Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #161881 4th Jan 2013 4:50pm
woodchopper23
I'll give it another try ..... MY2010 TDV8 Vogue Ipanema Sand
Post #161889 4th Jan 2013 5:14pm
woodchopper23
Nope.... Cannot get any codes to work. Even thought its in black and white on the site. I'll try calling them tomorrow. MY2010 TDV8 Vogue Ipanema Sand
Post #161897 4th Jan 2013 5:28pm
Page 2 of 3 <123>
