Home > Technical (L322) > Tdv8 starter glitch. |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 |
Hi all, I have had my 61 plate TDV8 for a month now and a couple issues have arisen, first off every once in a while pressing the starter only results in a single click and no starter engagement, when this happens it sometimes does it 5 one 6 times before the starter engages and then all is well for maybe 2 or 3 days. The other problem I have is again sporadic, after maybe 20 minutes driving time the SRS warning light will come on and stay on until the engine is stopped and restarted. Again this doesn't always happen and although It is in for 1st service on Monday I was worried the dealer may not be able to replicate these faults. What I want to know really is will history of these show up on the diagnostic computer at the dealers and has anyone else had similar occurrences. I've just remembered the park heater doesn't work either when I set the timer or try to switch on with the remote. Seems it might be a long day on Monday. Agueroooooooooo. 93-20
21st Sep 2012 2:32pm |
If i was you i'd use your phone to record them as evidence as some faults can self clear and leave no evidence.
21st Sep 2012 3:41pm |
Just a quick update on the original post, after collecting the car after service dealer put both faults down to slightly low battery volts and charged battery for a couple of hours, this did not seem correct as the SRS light was coming on after 20 minutes or so driving time when the system volts would be relatively high also the starter problem would sometimes occur after a run. Sure enough after a day or so the faults showed up again and while the SRS light was on I went into the hidden menu and found system volts reading 14.4 vdc. Booked the car in again and on the way to the dealer the light appeared again so left the engine running whilst booking the car in so the could test with the fault showing.
12th Oct 2012 10:01am |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
The annoying thing is that they thought you stupid enough to be satisfied with their first ridiculous diagnosis. If the volts were low, then charging the battery isn't the answer - finding out why they are low and fixing the root cause is the answer.
12th Oct 2012 2:36pm |
They put the low volts down to me using the car for predominantly short journeys and at the time I had to except that until I could tell differently. I've dealt with DC control systems for the last twenty years so I know my way around them a little but it's no use arguing with a service receptionist whilst having no actual ammunition. The fact that they thought it ok to pay £60.000 for a car that won't cope with short trips seemed to pass them by though! Agueroooooooooo. 93-20 I swear you will never see anything like this ever again....watch it..drink it in. |
13th Oct 2012 8:09am |
