![]() | Home > Technical (L322) > No HVAC fans, Final stage resistor removed |
swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69 ![]() ![]() ![]() |
I hope so, or another problem is lurking, but that would be negative.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
Fuse 34? 7.5A |
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 ![]() ![]() ![]() |
Tried fuse 34 to no avail
What I would do is test the motor as follows.
No luck |
UPDATE: Half a year later...
If you still have the FSR you took out as being faulty you could try refitting it in place of the "new one" and see what happens. |
Replaced the FSR with the old one just now, everything worked as it should again,, speed control and all.
Interesting.
I don't think it's a dodgy connection as it would stop, start and work at the desired speed before I took the key out. Key back-in 2min later and it's back to how it was.
As long as you are satisfied it's not a bad connection I would put the "new FSR" back in. Set the speed control knob to max and switch on the ign and see what happens. |
No luck, I've tried full speed before ignition on. Check all fuses and checked the FSR connection. The FSR is slightly warm so it's receiving power and I know the fan works along with the controls.
Could of course be a faulty rotary fan speed selector switch.
I don't want to be one of these people who leave this thread without an ending, I know there will be people finding this on google by looking for solutions to their own problems
