![]() | Home > General > Folding Rear Seats |
allycraven Member Since: 28 Mar 2011 Location: North Craigo, Angus Posts: 440 ![]() ![]() |
The entire seat unit hinges over behind the front seats to give a flat bed. |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
As above. When the seats are folded down, just pull on the back of the seat (at the hinge point) and it will pull up and forwards 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
You will not got a flat load area from the folded seats all the way to the tailgate. Where the seats sit there is a lip and then a recess for the seat bases, its not like a disco or SSRR. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
baldylocks Member Since: 05 Apr 2010 Location: Gods Own County Posts: 42 ![]() ![]() ![]() |
Thanks guys |
aneurysm1 Member Since: 12 Dec 2012 Location: burnley Posts: 202 ![]() ![]() |
Hi guys,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35808 ![]() ![]() |
the back of the seat folds forward onto the bit where you put your bum... ... - .- -.
So am i right in thinking they wont go completely flat to accomodate a cage? i know i will have a better idea when i look at one and play around but its quite an important aspect that i can fit my current dog cage in, and it doesnt with the seats up. |
they will be up slightly, i'd say about a 15 degee 'ish angle.. ... - .- -.
Thanks for that stan! |
If you fold them away completely you'll get a dog cage in easy. There is a gap under the front of the cage so you'll have to pack it with something. |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
Hi
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1240 ![]() ![]() ![]() |
As explained above you can fold the seats in two steps.
Fleagle where in cheshire are you as your welcome to come and see mine if you want and see what they are like in the flesh without a salesman breathing down your neck |
thanks for the description so it sounds like that once the seat is swung up, the base of the boot floor then drops into a 'well' where the seat base was. mmmmmmmm |
