Home > Maintenance & Mods (L322) > Occasional rear drivers airbag deflation!
supershuttle
The rear on the drivers side has on two occasions dropped when parked overnight. When I start up it quickly levels, is this just a "feature" or should I be a bit more worried. I did a search but the info was a bit inconclusive and also it seemed aimed at a DIY maintenance man - which I'm not.
Obviously I don't want to panic but should I start saving up Sad Geoff
Post #146700 17th Oct 2012 10:43am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Sounds like a leak. It's certainly not normal.
Post #146708 17th Oct 2012 11:13am
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
I'd carry out the soapy water test to see if there is a leak ... African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #146716 17th Oct 2012 11:39am
supershuttle
See: there you go DIY stuff in this weather Shocked
I also found a fault recorded on my IDTool under RML-Suspension: C1A00 Control Module. I've pinged the helpful Gap guys an e-mail.
It also has a related trick of adjusting its height at traffic lights every now and again.
I thought it had been trouble free for too long, just gone over 70k maybe it's just getting old!! Geoff
Post #146743 17th Oct 2012 3:51pm
Goldy
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
sorry to bring back an old thread.
I am getting c1a00 Control Module fault. When its cleared it returns right away without moving the vehicle.
supershuttle did you get to the bottom of your fault?
I have recently changed a front strut but all seems ok at the moment.
This fault has been there since the stut failed.
Post #396622 18th Jul 2016 4:32pm
