![]() | Home > Maintenance & Mods (L322) > A gearbox-shaped cry for help |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
MPG is about right for a V8 in and around London...
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 ![]() ![]() ![]() |
I used JT Automatics in Erith just off M25 Dartford side for my TD6, they were spot on and very reasonable, i paid £1830 inc vat with a 2 year warrenty to fully rebuild my current transmission......give them a call |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
What symptoms is your box showing? RRPhil is a ZF box wizard and will probably help you diagnose the fault and how to fix with a bit of info. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
fergus31 Member Since: 18 Oct 2012 Location: Surrey Posts: 3 ![]() ![]() ![]() |
Many thanks for the various replies.
Fergus I'm no expert but you can do a gearbox reset that it will then learn your style of driving and settings needed. If the prev owner booted it everywhere if might have learned that style. If you haven't done it already unlock the car, get in and push the accelerator to the floor (remember to go through the kick down), key in ignition with foot still hard down, turn to position 2, hold the acc down for 30-40 sec then release, take keys out and restart.
Thanks Rob, that's good chat - I'll try that reset routine tomorrow.
Have a look at the gear linkage threads as well, some of your problems could be related to the gear linkage being "out of lube". MY 2010 5.0 SC Galway green and sand interior!!
