Home > Technical (L322) > Full closure alarm
Neil E
2019 Range Rover 2.0 PHEV Mariana Black
Options below:
Personalisable feature Options Note Default Setting System
Wiper slowdown Active / Inactive Step down wiper speed at rest (e.g from slow wipe to intermittent) Only on Non Rain Sensor Cars Active BCU
Autolock repeat disable Active / Inactive Specifiy whether autolocking (speed locking) operates more than once per ignition cycle Inactive BCU
SPE Key 1 Active / Inactive Specify whether key 1 has single point entry Active US/Canada. Inactive RoW BCU
SPE Key 2 Active / Inactive Specify whether key 2 has single point entry Active US/Canada. Inactive RoW BCU
SPE Key 3 Active / Inactive Specify whether key 3 has single point entry Active US/Canada. Inactive RoW BCU
SPE Key 4 Active / Inactive Specify whether key 4 has single point entry Active US/Canada. Inactive RoW BCU
Autolock Key 1 Active / Inactive Specify whether key 1 has autolocking (speed locking) Inactive BCU
Autolock Key 2 Active / Inactive Specify whether key 2 has autolocking (speed locking) Inactive BCU
Autolock Key 3 Active / Inactive Specify whether key 3 has autolocking (speed locking) Inactive BCU
Autolock Key 4 Active / Inactive Specify whether key 4 has autolocking (speed locking) Inactive BCU
Lazy vent Active / Inactive Specify whether vehicle has global window / sunroof opening via key Active BCU
Lazy lock Active / Inactive Specify whether vehicle has global window / sunroof closing via key Active BCU
Lazy lock with remote Active / Inactive Specify whether vehicle has global window / sunroof opening via remote handset Inactive : US / Canada / Australia
Active : RoW
BCU
Auto 2 min relock Active / Inactive Specify whether vehicle automatically relocks after 2 mins of being unlocked and no doors opened Inactive BCU
Panic alarm Active / Inactive Specify whether panic alarm operates via remote handset tailgate unlock button Inactive BCU
Arrival time clock 12 hours / 24 hours 12hrs : RHD vehicles with MPH instrument pack, US, Canada, South Africa, Australia, Gulf, Japan
24hrs : RoW
Inst Pack
Distance units km / miles Depends on Instrument Pack Inst Pack
Distance limit units kmh / mph Depends on Instrument Pack Inst Pack
Speed units kmh / mph Depends on Instrument Pack Inst Pack
BordComputer with ignition Active / Inactive Specify whether BordMonitor (MFD) operates when door opened or when key in ignition Active Inst Pack
Temperature units Centigrade / fahrenheit ºF : US and Canada
ºC : ROW
Inst Pack
Time units 12 hours / 24 hours 12hrs : RHD vehicles with MPH instrument pack, US, Canada, South Africa, Australia, Gulf, Japan
24hrs : RoW
Inst Pack
Timer 2 units 12 hours / 24 hours 12hrs : RHD vehicles with MPH instrument pack, US, Canada, South Africa, Australia, Gulf, Japan
24hrs : RoW
Inst Pack
Timer 1 units 12 hours / 24 hours 12hrs : RHD vehicles with MPH instrument pack, US, Canada, South Africa, Australia, Gulf, Japan
24hrs : RoW
Inst Pack
Range units km / miles Depends on Instrument Pack Inst Pack
Fuel cons units 2 l/100km / MPG - UK / MPG - US km_l : Japan
mpg_us : US
mpg_uk : RHD vehicles with MPH instrument pack
l_100km : RoW
Inst Pack
Fuel cons units 1 l/100km / MPG - UK / MPG - US km_l : Japan
mpg_us : US
l_100km : RoW
Inst Pack
Ext temp warning gong Active / Inactive Specifies whether low ambient temperature (frost) warning sounds Active Inst Pack
Instrument pack language German / UK English / US English /
Italian / Spanish / Japanese / French /
Canadian / Gulf
Depends on Market programmed Inst Pack
Daytime Running Lights Active / Inactive Both this and the 'Dip Beam with daytime running lights' feature needs to be active for DRL operation Active : Non-Canadian vehicles with daytime running
Inactive : RoW (Including Canada)
LCM
Dip beam with daytime running lights Active / Inactive Both this and the 'daytime running lights' feature needs to be active for DRL operation Active : Non-Canadian vehicles with daytime running
LCM
Follow Me Home delay None / 40s / 90s / 150s / 240s Set timeout for any follow me home lights Active : Non-Canadian vehicles with daytime running
LCM
Follow Me Home with dipped beam Active / Inactive Specifies use of dipped beam for Follow Me Home feature 40 seconds LCM
Follow Me Home with rear position lamps Active / Inactive Specifies use of rear position lamps for Follow Me Home feature Active LCM
Follow Me Home with front position lamps Active / Inactive Specifies use of front position lamps for Follow Me Home feature Active LCM
Follow Me Home with interior illumination Active / Inactive Specifies use of interior illumination for Follow Me Home feature Active LCM
Follow Me Home with Licence Plate lamps Active / Inactive Specifies use of licence plate lamps for Follow Me Home feature Active LCM
Follow Me Home with Front fog lights Active / Inactive Specifies use of front fog lights for Follow Me Home feature Inactive LCM
Follow Me Home with Main Beam Active / Inactive Specifies use of main beam for Follow Me Home feature Inactive LCM
Follow Me Home with Rear fog lights Active / Inactive Specifies use of rear fog lights for Follow Me Home feature Inactive LCM
Follow Me Home with Reverse lamps Active / Inactive Specifies use of reverse lamps for Follow Me Home feature Inactive LCM
Default speed dependant volume Option 1 / 2 / 3 / 4 / 5 / 6 Specify automatic volume control (speed dependant) level (1 low, 6 high) Option 2 DSP
Radio Key Memory Enable / Disable Specify whether radio presets are personaliased to remote handset (I.e. each handset has own
presets)
Enable Radio
RDC Number of Sensors Four / Five Specify whether spare tyre is full spare (has RDC sensor transmitter) or spacesaver (no RDC sensor
transmitter)
4 : Vehicles with Space Saver
5 : Full Spare
TPMS
RDC Monitor Number None / Four Specify whether RDC operates on all four wheels or not Four TPMS
PDC Audible Warning Active / Inactive Specify whether audible warning sounds momentarily when PDC selected Active PDC
PDC Rear Volume Option 1 / 2 / 3 / 4 / 5 / 6 Specify rear PDC sounder volume level (1 low, 6 high) Option 3 PDC
Thumbs Up Thumbs Up MY21 P400e AB
MY10 3.6 TD V8 Autobiography
55 Vogue se
Post #14703 11th Mar 2010 12:16am
dan_uk_1984
Neil E wrote:
Dan just read your post on RR.net!!!
http://www.rangerovers.net/forum/viewtopic.php?f=2&t=36898
Rolling with laughter Rolling with laughter Rolling with laughter
Yeah, prolly why I got banned.....
I'll help absolutely anyone who's willing to help themselves. Ask for it on a silver platter and I'll flame ur ass though!
Post #14704 11th Mar 2010 12:19am
Andy
Mine sends the windows up when I hold the button as well.... 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #14734 11th Mar 2010 8:26pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
You are all wrong.
"Full Closure alarm" is what the wife inflicts if you play about and get found out. Typically you wake up in a field with just your pants, no house, Range Rover or pension (when you get to claim it). Laughing ... or Big Cry if you happen to be going through it Laughing Neutral
Post #14742 11th Mar 2010 9:18pm
Neil E
I went to the stealers today and they said they could set the car up to have the full closure alarm and the central locking at speed (and anything else which is worth having) and they`d charge half an hour for it (£62).
Booked it in! MY21 P400e AB
55 Vogue se
Post #14754 11th Mar 2010 10:19pm
Post #14755 11th Mar 2010 10:19pm
