Home > In Car Electronics (L322) > CD Player/Intravee Question
baldylocks
United Kingdom 2004 Range Rover Vogue Td6 Bonatti Grey
Evening all
I've picked the new FF up today (2004 TD6 Vogue) and top of the list is Intravee installation. I have to establish what sort of plug(s) are on the back of the CD player to hook it up but I've searched on here and YouTube and can't find any details of how to get to the back of it.
Can anyone oblige?
Many thanks
Gerry
Post #147133 19th Oct 2012 11:44pm
If its an 04 you will have the wrong plug for sure... You will need to change the big one for two smaller ones either via a connector cable or cut the one off you have and re-wire the early plugs back on...
You need to drop the glovebox down to undo the torx head fixings inside holding the multiplay in... Youtube?
Craig Thumbs Up
Post #147144 20th Oct 2012 8:15am
mjdronfield
As a poss alternative, not sure exactly what you are looking to do, but Baris on here offers a reasonably priced upgrade to digital TV, using the analog unit in the car, that adds usb connection, mp3 and can also add ipod stuff to the radio as part of a seperate amp upgrade.....
http://www.fullfatrr.com/forum/topic13727.html?highlight=baris
http://www.fullfatrr.com/forum/topic10342.html?highlight=baris
The amp upgrade is well worth it by itself, if you want decent sound quality from the standard setup......
Back to your question ;
To remove the CD Changer..........
http://www.roverupgrades.com/Range_Rover_MP3_Cd_Changer.html
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #147166 20th Oct 2012 10:21am
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
As mjdronfield said just follow the instructions on the rover upgrade site. Just make sure that when you put it all back together you check that the glovebox opener cable is connected properly. It's not much fun having a glovebox that won't open, as I found out. Thank god for wire coathangers! And for the 10 pin to 6 pin and 3 pin conversion, I went to a scrapyard and cut them out of the boot of a 3 series then paid £1 for the privelege. Re-pinning takes just ten minutes and then the Intravee is ready to go!
Post #147232 20th Oct 2012 5:44pm
baldylocks
Thanks guys, some useful info there. In essence all I want to do is have an ipod hardwired in to the car and controlled through the head unit. I though about bluetooth streaming from my phone but I struggle with the battery life anyway so figured if I use my spare ipod it will always be there.
I've spent the day cleaning it while the weather has been OK, I'll get it in the garage tomorrow and have a look at the CD changer.
Post #147241 20th Oct 2012 6:46pm
