Home > Technical (L322) > L322 TD6 GM5L40 Gearbox upgrades
Upgrade List wrote:
Upgraded Sonnax Valve Block
Upgraded Sonnax Oil Pump
Ok So far we all know that the valve block should be upgraded if possible to the uprated Sonnax valve block.
Are there any other upgrades bar normal maintenance that should/could be done?
Possibly a longer 5th gear or final drive ratio to decrease cruising RPM and thus increase MPG?
An upgrade that can make it lockup quicker at all?
Im guessing RRPhil is the best person in the know about these gearbox's Smile
Just interested as per my WTD add there isn't anything wrong with mine (TOUCH WOOD!) but i'd like to strip down a box just incase and see about upgrades and the valve block is first but anything i can do to improve its use ability would be great and a better and quicker lockup function would be much better i think Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #147439 22nd Oct 2012 10:28am
mjdronfield
When I got quotes from suppliers who did the Sonnax upgrade, one mentioned a Sonnax oil pump. Theirs had the Sonnax valve block and oil pump fitted for £1495 +VAT and £500 exchange surcharge on your old box. That was supply only. You'd have to get the box fitted yourself. Just to give you an idea of prices.
I have also read about the clutch plates being upgraded.
A taller 5th gear would be useful......as you say.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #147441 22nd Oct 2012 10:34am
Cool I'll add that to the original Post so we have a post with all the bits on it which can then be wiki'd Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #147442 22nd Oct 2012 10:35am
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
If you look hard you may be able to find an upgrated Torque converter as well as this is where some of the problems come from. The disintergration of the plates in the T/C. Someone over here was going to build a modified T/C
Gary
Post #147496 22nd Oct 2012 3:38pm
Hmm best drop an email to mackies then Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #147499 22nd Oct 2012 3:52pm
mjdronfield
I had a couple of emails from Mackies, but there were conflicting warranty information for the torque converter ;
Morning mark
The cost to recondition both transmission & torque converter is £1850.00+vat,
We fully recondition your transmission & torque converter to manufacturers specifications including the sonnax valve/body upgrade and all this is done here at our premises mark,
We recondition your torque converter in house and it has a life time warranty,
Yes mark you need to replace the transmission oil cooler 100% as the fine metal lodges inside and it is impossible to get it all out, so best to replace it,
Hope this helps you to decide mark.
then ;
Mark
Sorry I forgot to mention in my e-mail that if we do the complete job at a cost of £2642.63+ vat it comes with a three year warranty (parts and labour), if we supply the exchange transmission only then it has a 1 year warranty on the transmission & torque converter only.
Kind regards
John.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #147503 22nd Oct 2012 3:57pm
Hmm that is confusing... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #147504 22nd Oct 2012 3:59pm
Well machines have said that an upgrade to the gearing isn't possible and that an upgraded torque converter isn't available.
Going to get a price on the sonnax valve block and oil pump upgrade tomorrow but they have said I'd need specialist tools to do the work on the vale body an oil pump.
It's a shame I can't upgrade the gearing in it Sad
They have confirmed that the zf boxes used on the tdv8 are much stronger and regular oil changes should make them last a long long time Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #147523 22nd Oct 2012 6:42pm
