Home > Wheels & Tyres > Maximum size tires on a 2012 with 20" wheels
Tahoe Dave
United States 2012 Range Rover HSE 5.0 V8 Fuji White
As the title of the post suggest, I am curious how large I can go if I replace the stock tires on my 2012 FFRR. The OE 255/50 20's are 30.2" in diameter with a 9" tread width.
The choices for this size is very limited. Alternatively, there are several choices in the size 275/60 20. This size is 33" in diameter with a 9.2" tread.
Any thoughts? 2012 Range Rover HSE LUX
2006 Range Rover Sport
2008 Jaguar XK
Post #147640 23rd Oct 2012 2:15pm
speedo will out by nearly 8mph..
Post #147642 23rd Oct 2012 2:27pm
How large can you go without rubbing ? Or how wide can you go & keep the indicated speed true ?
305/45R20: About 2 inches wider than stock but only 0.8 inches taller.
285/50R20: This is 31.26 inches in diameter and 11.6 inches wide, and should fit quite well.
285/55R20: This size is about 32.5 inches in diameter and would be at the upper limit of fitting without vehicle modification.
Post #147692 23rd Oct 2012 7:52pm
daz62
United Kingdom 2003 Range Rover Vogue SE 4.4 V8 Oslo Blue
Wouldn't the actual wheel width make a difference to choice of tyre width? Stan mentioned sport wheels are wider than standard FF wheels in another post.
Just wondering cos I want to fit wider tyres on my 8.5 wide 20 rims come renewal time. 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #147698 23rd Oct 2012 8:34pm
indeed, RRS wheels are 9.5j and wheni had them i had 295/45/20 tyres fitted.. ... - .- -.
Post #147705 23rd Oct 2012 9:02pm
iozrob
United States
275/60R20 may fit... but there'll be a lot of rubbing, and you'll need a wheel that's more offset. I have 275/55R20 now and it just barely fits in. Have been offroading on these and driving up to the mountains the past few seasons and they've been fine.
Post #147728 24th Oct 2012 12:03am
fisha
275/55 R20 Cooper LTZ's fitted to my 2002 RR... its a close fit with only very occassional rubbing , but assuming the 2012 doesn't have significantly different wheel wells then you should be fine. V8 or else ...
Post #147998 25th Oct 2012 11:38am
