![]() | Home > Technical (L322) > Wind noise at speed from around windscreen.. |
correct it's not fitted properly same issue on mine I removed and used a little black sealant job done noise gone. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7987 ![]() ![]() ![]() |
i had that. its the plastic scuttle panel under the wipers vibrating.
sorry - on ps3 so typing takes 400 years !
CBH25 Member Since: 18 Feb 2012 Location: Sunshine Coast, Australia Posts: 82 ![]() ![]() ![]() |
Guys another thin to check is the AIR CON.
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 ![]() ![]() |
Thanks guys, at the weekend i shall remove the scuttle and see if i can fix it. Its not the A/C as i did wonder that myself and made sure everything was off when i checked for the noise. Thanks |
Removing the scuttle and placing some more silicone sealant along it and putting back will fix it once and for all, but I just pressed mine down and jiggled it about (!!) and eventually the noise stopped. So you don't have to remove the whole thing if you are lucky.
T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187 ![]() ![]() ![]() |
[quote="mjdronfield"]
I just replaced the clips that hold it on. You can get to them when the front door is open.
Cheers! |
Glideman Member Since: 11 Sep 2011 Location: Stood next to a broken down Range Rover in Darwen Posts: 112 ![]() ![]() ![]() |
Must check mine as I had the windscreen replaced a couple of weeks ago & now it's making a hell of a racket at about 60-70 MPH. Range Rover 4.4 V8 Vogue |
