![]() | Home > Technical (L322) > Engine system fault at altitude |
Geraint Member Since: 01 Apr 2010 Location: Banbury Posts: 8 ![]() ![]() ![]() |
Hi
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35864 ![]() ![]() |
any help?
Thanks Stan
i dont think a positive solution was found but hopefully this resurrected problem might get some more ideas..
i bet Martins a spotty 14 year old working out of his bedroom. |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Sounds like you just need to fit a louder radio to drown her out. Much simpler than trying to fix the FF... |
![]() He's left his webcam on... |
a smoker as well.. |
My first thoughts would be that as you go higher, the air becomes thinner and something is not reacting to that properly. So MAF or blocked air cleaner. MAF would be my first thought though. |
Unfortunately I don't have access to the EM schematics of the TDV8. As in the other post, I would suspect the MAP sensor (MAF only measure flow and temperature) as it measures pressure (the only variable that seems to cause the issue). However I am not sure the TDV8 has a MAP sensor (like the S/C), I checked the TD6 and it does not have a MAP sensor.
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
I believe that the TDV8 does have a MAP sensor, there was some chatter about cleaning the MAP sensors on the TDV6 led initially by the boys on Disco3.
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
We've cleaned the TMAP sensor (there are a pair directly under the engine cover), so just off on a quick trip to the Alps for testing.......
were they dirty? ... - .- -.
Forecasts are predicting a "snowy" weekend for the Alps |
