![]() | Home > Maintenance & Mods (L322) > Brighter reverse lights? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35832 ![]() ![]() |
i think this is the correct setup.
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1118 ![]() ![]() |
That will be 12N I guess. letters not necessarily in the right order |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Usually the numbers are printed under the flap on the socket |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Living in an area without street lights I decided to do something about the woefully inadequate reverse lights on my car.
good job that.. |
Yes you could wire a feed from the tow bar electrics, either plugging into the socket or tapping into the cables inside the boot.
not such a bad thing i suppose ..it'll certainly warn others that you're reversing.. ![]() Y. O. L. O. . |
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 ![]() ![]() ![]() |
Wonder if some of the thin linear DRL fittings you see on Fleabay would mount alongside the standard reverse lamps?
