Home > Technical (L322) > Anyone know what this part is / does? |
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 |
Starter inhibitor? To stop you turning engine over unless in Park or Neutral?
27th Oct 2012 6:12pm |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 734 |
I could be wrong, but I think the inhibitor is bolted to the gearbox. |
27th Oct 2012 7:28pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
its the unit that holds your key transponder details, EWS unit V8 facelift Range Rover Autobiography 22" wheels.
27th Oct 2012 7:36pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
When you put the key in does the steering wheel unlock? I was thinking the battery in the key fob might be flat. Previously..
27th Oct 2012 7:39pm |
Ohh, that doesn't sound good (sounds expensive)
27th Oct 2012 7:41pm |
Yes, every time, no problems.. |
27th Oct 2012 7:42pm |
the unit looks for the transponder chip in the key and if it see's it you will here the ignition lock clunk..if you have a flat battery or even no battery in the key fob it will make no difference to its operation, if you can put the key in the ignition and it turns then its working, does the engine crank over V8 facelift Range Rover Autobiography 22" wheels.
27th Oct 2012 7:52pm |
Thank you for your help..
27th Oct 2012 8:04pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3956 |
Could this not be a sticky selector cable not allowing the auto box inhibitor switch into the correct position for starter operation? |
27th Oct 2012 8:07pm |
I'll have a look tomorrow, but I did try working it back and forth, also tried in 'N' with no luck. |
27th Oct 2012 8:17pm |
Have a look at this, although you don't have the symtoms listed, lack of lubrication on the bottom end of the cable could affect the inhibitor switch.
27th Oct 2012 8:25pm |
