Home > In Car Electronics (L322) > MK 4 sat nav problems
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
Hi all
I upgraded my old sat nav to the mk4 about a year ago and it's been fantastic,
Off to derby on Saturday i was about 45 mins in to the journey when the screen decides to go blank
Then reboot its self as if I'd just got in the car????
This happened about 6 times in a row, now it will not load the sat nav but doesn't say can't read disc etc
Just please wait???
Help RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #148745 29th Oct 2012 9:05am
mjdronfield
its not a copied disk is it ?
or non gen firmware ?
i know its been working fine, but i have read about lockups and reboots with non gen stuff...........
perhaps the laser is on it's last legs ?
i'd clean the disk or try another from somewhere as the next step......... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #148747 29th Oct 2012 9:21am
if possible try another disc, this will determine if the disc or the nav unit is faulty.. ... - .- -.
Post #148754 29th Oct 2012 9:52am
I had a similar problem one time that a battery disconnect - reconnect seemed to clear up.
Post #148781 29th Oct 2012 11:58am
daveo
i had this as well, at the time it was ether weather,being damp or the software, i was using the latest disc with cameras ..i downgraded and reloaded with standard version of v3.2 non speed camera, all ok V8 facelift Range Rover Autobiography 22" wheels.
Post #148864 29th Oct 2012 8:27pm
Jr-auto-electrics
Update...
Tried to eject the DVD tonight but would not come out
Tried all 3 ways but no go.
So I whipped it out flipped the lid off and loosened the drive motor
And manually wound the disc out slowly.
Popped it back in the car and it came on as norm and asked for a disc
So i put the copied DVD back in, only to a hear a very loud spinning noise
Disc out and back in again but still loud noise
So I popped the lid off while still powered up and had a little fiddle
While the noise was present.
Found it to be part of the drive rubbing on the edge of disc
A little tweek with small screw driver and hey presto
Fully working silent sat nav also seams faster than before.
Can't understand it as no ones been near it?? RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #148891 29th Oct 2012 10:59pm
