Home > In Car Electronics (L322) > another sat nav problem
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
my sat nav seems to be having a few issues, has for a while but have never got round to sorting it. basically only some of the buttons / functions are available to select with others ' greyed out ' so do nothing when pressed, so making selecting a destination impossible. i have another disc that i was going to try but not sure this will help. the actual map works and you can see where you are on the map etc just not some of the other functionality..... any ideas?
best
andy
Post #148805 29th Oct 2012 2:04pm
try the other disc
Post #148806 29th Oct 2012 2:09pm
I know it sounds too simple but is this problem when stationary or when moving ? 2008 MY Supercharged
Post #148807 29th Oct 2012 2:17pm
andyleeds
cheers gaz Wink
not sure, but i will see this afternoon and try it stood still.... but i think i have tried both..... its seems a bit temperamental it will allow you to add a postcode sometmes but then will stop half way through the postcode......
Post #148810 29th Oct 2012 2:26pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
When you say "stop" you don't mean that it's waiting for a space character before it will accept any more letters or numbers do you ?
Post #148811 29th Oct 2012 2:28pm
andyleeds
no, what i mean is that you can be typing in an address or postcode and the letter go grey so you cant select any.....
Post #148816 29th Oct 2012 2:52pm
andyleeds
well the plot thickens, as Axle suggested i tried the sat nav while stationary and it would seem that most of it worked with the exception of the post code part which still doesnt show the letters just the numbers, however when i started moving various parts greyed out? is this supposed to happen as i am sure it didnt happen before?
andy
Post #148837 29th Oct 2012 5:36pm
'nav on the move' is greyed out on the 2010 disc upgrades...this can be unlocked using the IIDTool if you have the correct firmware.. ... - .- -.
Post #148841 29th Oct 2012 5:52pm
andyleeds
i cant imagine that mine would have it being an 05 car? but i bought it in november 2010 so its possible but something must be wrong as teh letters are always greyed out when input via postcode..... does anyone know what the difference the latest disc might make?
Post #148845 29th Oct 2012 6:01pm
have you tried the other disc Andy? ... - .- -.
Post #148846 29th Oct 2012 6:04pm
andyleeds
nope will try tomorrow, am guessing that i just have to take the old one out and add the new one?
Post #148851 29th Oct 2012 6:25pm
Martin
Site Admin
If it's only showing numbers on the post code entry then it sounds likely that the search country is set wrong (probably Belgium if you've updated the disc)
Post #148852 29th Oct 2012 6:28pm
VaguelyVogue
I'd forgotten about that one Martin (happened to me after driving back from Switzerland) - took a bit of head scratching to work out why the post codes were not working UK style!
Post #148894 29th Oct 2012 11:19pm
andyleeds
you guys were right on the money, was programmed to france! so all works now which is great (not that it was ever broken just me being stooopid)
so does anyone know what the new disc would be bring? am guessing just newer maps? is it just a case of changing the disc in the boot?
Post #149048 31st Oct 2012 11:16am
Martin
Site Admin
Yes, new maps. Depending on what year you've got now there may be a slight software update to the nav too, adding/updating some features.
Post #149049 31st Oct 2012 11:29am
