![]() | Home > Wheels & Tyres > Front wheel tracking |
4 wheel tracking for the FFRR |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35848 ![]() ![]() |
![]() ![]() Y. O. L. O. . |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2720 ![]() ![]() ![]() |
Strathearn engineering Auchterarder £75 +vat , well worth getting it done by folk who have a clue! |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
After 2 years my back wheels are showing even wear across the surface, so I am sure the rear is ok. It's just my front toe in/out I need to adjust. Surely you can just do the front if needed without doing all 4 together? Previously..
Spoken like a true Fifer, love it. Why not buy a couple of spirit levels, cable tie them on & you'll be braw! Adjust to suit, job done!, |
There's an idea... My laser level, a couple of mirrors and a tape measure, sorted.
I was also thinking you might get use out of a couple of laser pens too!! |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3269 ![]() ![]() ![]() |
I got mine done by Protyre for £50. they were the only ones who had the right type of kit (cant remember what it was but it is needed for 4x4 vehicles and apparently you need to get all 4 done at the same time.)
Problem with only adjusting the front is that if they make adjustments to only one side it can throw the steering sensor out which will throw up a fault and put half the electrics into safe mode. |
Ah.. |
You could be lucky and get someone who knows what he is doing and everything will be fine, but there again you may be unlucky.
Thats wot I sed!! |
^^^ You said Protyre |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
+1 needs to be 4 wheel aligned to keep everything true, the old days of Dunlop alignment gauges are well and truly gone, might have been OK on a live axle but things move on ![]() |
