Home > My Range Rover > My Bonatti Grey 2004 Vogue
Page 2 of 3 <123>
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Steve
If you can get the plastic stic on door handle covers. Alot cheaper and what most do.
Post #14601 9th Mar 2010 5:30pm
Painting:
Post #14603 9th Mar 2010 5:34pm
Steve R
United Kingdom 2004 Range Rover Vogue 4.4 V8 Stornoway Grey
Now that looks really good. Out of curoisity did they stay looking that good for very long? I wasn't sure if I'd need to get them professionally painted and baked on for it to last. If it worked well then I'll probably give that a go. I guess if I make a total mess of it I can buy some stick-on covers!
Thanks for the photos, very useful.
Steve.
Post #14605 9th Mar 2010 5:46pm
Steve.
It was not me but I read about it at http://www.rangerovers.net/forum/viewtopic...es#p283070 and it seemed like a really good job.
Post #14606 9th Mar 2010 5:51pm
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
Nice motor! The colour i would have gone for had i not found the right black one.
Loving the pics especially picture two !!!! Bow down TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #14612 9th Mar 2010 7:44pm
Steve R
Thanks, I think I was just lucky to find one in my favourite colour after much hunting around (and looking at basket cases).
Reckon I'll give the handle painting a go when it gets a bit warmer, I'll post some photos on here once I've done it.
One final question - are the handles, er, handed? I'd still consider swapping the n/s and o/s handles with each other if it's not too difficult because the underneath and outside faces are perfect, it's just the tops that are worn...
Steve.
Post #14615 9th Mar 2010 8:26pm
scotty7
Scotland 2003 Range Rover Vogue Td6 Buckingham Blue
hi steve nice lookin motor,
intersted to know how you removed the door rubbing strips, are they just stuck on?
was the paint-work underneath ok?
i do think it looks better for not having them
cheers scotty
Post #14616 9th Mar 2010 8:41pm
Steve R
Hi Scotty,
Must admit the rubbing strips were a nightmare! Yes, they are stuck on with mega sticky double sided around their edge (about 10mm wide strip all the way round).
I managed to get them off by heating up slightly with a hot air gun, getting a blunt knife under the edge (watch the paint!), then carefully peeling them off. You have to be careful because you may damage the plastic door bottom finisher that they're stuck on to - it flexes quite a lot!
Then you're just left with a sticky mess to peel off millimetre by millimetre - I used fingernails and white spirit on a rag so I didn't damage the paint and it took absolutely ages, following up with a good polish. Luckily the paint was perfect underneath, I'm guessing they were fitted from new. There must be a better way to get the sticky off though...
Have fun! Very Happy
Post #14619 9th Mar 2010 9:04pm
They just stick on with 3m tape Scotty i bought mine from Shields years ago and stuck them on, only reason i put them on was because of the Censored that bang your door in car parks .............
Probably if i took them off i would need to do a bit of t-cutting to bring the colour back .......
Post #14621 9th Mar 2010 9:07pm
scotty7
cheers folks,,
might have a go at this when the light nights come in.
two of mine are peeling off already at the edges so hopefully come off easy
cheers scotty
Post #14625 9th Mar 2010 9:34pm
daveo
hi, the last pic would make a good splash screen for the nav.... V8 facelift Range Rover Autobiography 22" wheels.
Post #14634 9th Mar 2010 10:35pm
Daveo your Nav mad mate Laughing
Post #14642 9th Mar 2010 11:50pm
Steve R
Right, I've made a decision and have just ordered a set of the plastic handle covers and some genuine Bonatti Grey spray paint and lacquer. Decided this would be easier than spraying the originals on the car - wasn't totally sure how I'd get to the back of the handles.
Will let you know how I get on...
Post #14852 14th Mar 2010 6:50pm
Should look great and your no worse off if it doesn't as you can take them off again Exclamation
Look forward to update soon....
Post #14853 14th Mar 2010 7:14pm
SGW
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
Hi Steve, where did you get your covers from, are they just in primer or finished in the original colour.
Many thanks.
Stewart.
Post #14911 15th Mar 2010 11:11pm
Page 2 of 3 <123>
