![]() | Home > Technical (L322) > TD6 Tuning Question |
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
When I had a TD6 I used Pentagon who are SuperChips agents .
| PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877
http://bellautoservices.co.uk/bas-remap-interface/
| marcoos_1 Member Since: 25 Oct 2012 Location: Glasgow Posts: 138
Thanks guys,
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2724
I have the Tunit box fitted, although never driven a standard car, performance is more than adequate for the size of car. Whichever route you take, a very worthwhile upgrade. |
| Tesh Member Since: 27 Feb 2010 Location: Co Durham Posts: 138
Word of Warning!!!!!
Dont agree... Most cars i look after are tuned in some way and no more failures then without... Craig |
Oh god.....are they really that bad?
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8001
The GM gearboxes in the Td6 tend to fail due to the valve bodies being made from slightly softer aluminium. The bores wear and deposit metal bits in the oil, which thus causes more wear. The wear causes a drop in hydraulic pressure which tends to make the clutches ? work a bit harder...... the only real fix is a valve block with the Sonnax upgrade, which effectively lines the bores with harder steel and stops the wear.
I don't know if my car has had a gearbox replaced......it's done 119k miles and seems ok so far....but then I've only had it a few days!!!!!!!
I also think,if you get a proper remap, it doesn't put your gearbox at any further risk.
I thought the extra torque created by a remap puts strain on the auto box? |
I started a thread about renewing my warranty, but it appears from their web site that they only deal with the motor trade, could be wrong.
| Lighty Member Since: 14 Oct 2012 Location: Manchester Posts: 7 |
The most important thing with the boxes on these things is make sure you service the bloody "Sealed for life" thing!!! It costs me 80 quid for new gearbox filter oil and all orings/gaskets and new bolts for sump. Takes an hour to do it properly I put it on the ramps drop it, clean it all out put new filter in and oil in run it for a week then the following weekend ill flush that new oil back out and replace with new. I do that once every year if I can be arsed but if I waited 2 years itd be fine too. DO that and youll stand more chance of it lasting at least. |
Ok......I took the plunge.......and ordered a tuning box from from Race Chip in Germany - the company that supplied my friend with one 4yrs ago for his car.
| All times are GMT |
