Home > Technical (L322) > Won't start - Immobiliser problems ?
Page 1 of 4 1234>
Johnte
I'm having trouble starting my TD6 Big Cry Sometime takes up to 50 turns of the key before it will start Shocked
Battery & starter are new within the last 6 months.
What I do get when I turn the key, is a noise (buzz/whirr) from inside the console, from what I'm told (from members of this forum Thumbs Up ) is the immobiliser . I've now had a Hawkeye plugged in and fault code says 'immobiliser (ews)'
Is this going to mean a costly trip to the main dealers Sad Sad
Any help or advice gratefully received.
Post #149277 1st Nov 2012 11:05am
when you put your key in it should make a clicking /whir noise, this indicates the gear release and immobiliser are off. ... - .- -.
Post #149278 1st Nov 2012 11:11am
ebajema
When you stick the key in, the immobilizer "releases" the electric steering lock (that is the click you hear in the steering column).
Is the problem only with one key or does it happen with the spare key(s) as well ??
When you stick the key in, jiggle the steering wheel a bit from left to right to make it easier for the lock to disengage, maybe that mechanism is struggling to disengage the lock. MY 2010 5.0 SC Galway green and sand interior!!
Post #149279 1st Nov 2012 11:18am
Johnte
Yes it does do that 'normal' sound, but this is a different one it makes (when the key is in the cranking position)
There's no problem turning the key, the lock disengages fine.
Post #149280 1st Nov 2012 11:19am
Martin
Site Admin
Is it the chatter from the starter solenoid? Your new starter might be duff Sad
Post #149281 1st Nov 2012 11:34am
see if the connections to the starter are sound... ... - .- -.
Post #149282 1st Nov 2012 11:36am
Johnte
The sound is from the immobiliser - you can also feel the high pitched vibration if you hold it when it's buzzing while cranking.
There's no power (when cranking) getting to the cable on the starter solenoid Confused
Post #149286 1st Nov 2012 11:49am
Martin
Site Admin
I don't know the L322 system, but I would have thought it unusual for an immobiliser to make a sound or vibrate Confused
Post #149287 1st Nov 2012 11:54am
so it does sound like the immobiliser then, Dan @ duckworths will give you a competitive price.. ... - .- -.
Post #149288 1st Nov 2012 11:54am
......you've obviously checked the wiring to the immobiliser... ... - .- -.
Post #149289 1st Nov 2012 11:55am
Johnte
Yes, I'm thinking I may need to bite the bullet and book it in at the dealers (If it will start) Sad
But, to be honest, it's an expense i could do without at the moment...
Post #149292 1st Nov 2012 11:58am
have you tried the spare key like Ebajema suggested..and i would recheck all connections to the battery , starter and immobiliser even going as far as dis/re connecting the battery...... ... - .- -.
Post #149294 1st Nov 2012 12:03pm
Johnte
Unfortunately the spare key has never worked since I got the car 2 yrs ago, battery was flat at the time, and when I replaced it, it wouldn't work - so it's been kicking about in the back of drawer ever since (another job I never got round to doing)
Yes, I've had all connections off and checked / cleaned them Sad
Post #149298 1st Nov 2012 12:11pm
So when you move the key to the cranking position the starter motor does not turn?
Sounds like a bad connection somewhere
Post #149301 1st Nov 2012 12:19pm
Faulty starter relay?
Post #149303 1st Nov 2012 12:24pm
Page 1 of 4 1234>
