Home > In Car Electronics (L322) > Luggage space lights not working
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
Looking for help please.
I've just changed the luggage space bulbs to LED and I caused I may have shorted the circuit whilst doing so. I've checked the fuses for the interior lights but they all look fine. Any ideas? The tailgate lights went in okay it was whilst changing the single bulb in the luggage bay that appears to caused the issue. Evil or Very Mad
Post #149694 4th Nov 2012 2:00pm
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
Led's only work one way round, try swapping it round first to check, also put the old bulb back to check if you still have 12v
Post #149708 4th Nov 2012 3:18pm
Buz1500
Thanks for the reply. I've tried that and still no joy.
I've actually just tried swapping the 20 amp fuse again and the lights came on but when I put the bulb cover back to put the light back into the trim housing on they all went out again. Tried a new fuse again (x3) but still not lighting again.
Post #149710 4th Nov 2012 3:37pm
netsonic Steve
if the fuse is blowing then you may be shorting it as you put the lamp back in to place, try removing the fuse then install the led into the holder and into the car then replace the fuse, ive put leds's into my 2002 vogue and never had this issue
Post #149718 4th Nov 2012 5:03pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
This happened to mine when I first put the LED's in. New fuse and battery disconnected for a couple of minutes sorted it.
Post #149817 5th Nov 2012 10:31am
