![]() | Home > Technical (L322) > steering column adjuster. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
this link is just one of many threads re the steering column...it is a common problem...i hope it helps.
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
@ Muffster, if you can describe me how to load pictures in the reply, I can show you the part you need, only a handmade screw! Regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
Wheres Mick when someones talking about not being able to get something IN and OUT?!?! |
mr meerbush, how to post pics...
Hi, you can see the part, what is defect, on Gallery, picture 1/4434, the black part under the t of the word motor, it is not to buy singular, only in handmade-rebuild! Can give you help, regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
muffster Member Since: 03 Dec 2011 Location: Bradford Posts: 71 ![]() ![]() |
I've read through some old threads and the more common issue seems to be with the tilt mechanism.
http://www.fullfatrr.com/gallery/displayim...;pos=-6184
Thanks ebajema, my english is not good enough for send pictures in my post..., it is the little black part, if I get an e-mail adress of muffster in the next reply, I can send a picture to muffster. L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
ebajema
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 ![]() ![]() ![]() |
I believe that the nylon white clip that holds the motor onto the spindle becomes brittle and snaps over time (this happened to mine). If you take off the panel which is the 'ceiling' to the footwell trim you should be able to see it. I fixed mine with a cable tie and it works fine! Hope this helps 2003 Vogue 4.4 V8 Java Black |
I think what Uli (Meerbusch) is referring to is the Reach Motor text on the picture. If you look directly below the t of the word motor, you see the spindle of the motor going through a black nut (or threaded block) that is slotted into the aluminium frame.
Great,
Exactly, was I said, and ebajema sees, is the problem, the black nut. I have made some examples here for friends in germany, one hour work with black plastic (nylon 12mm) per piece, the official bought also one |
Meerbusch
