|  | Home > Technical (L322) > Juddering |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35884    | i've always filled from supermarket pumps and only once have a had a very slight judder but a dose of wynns [or similar] in the fuel tank and it hasn't happened since ,but it could be a coincidence though and the wynns had no effect... ... - .- -.
|  6th Nov 2012 10:59am |
| crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698    | Thanks for both sets of advice i'll have to point out that the diesel advice came from the dealer I bought the car from not where the car is currently having diagnostic checks run on it.
|  6th Nov 2012 11:12am |
| Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964      |
 It sounds to me, if it's only happening from startup and when the temperature is cold that maybe you've got a glowplug or two not working. They are not expensive and should be treated as consumable items really - they are about the same to change (in terms of complexity) as a spark plug. It would make sense, then as the engine warms up, the cylinders without the assistance of the glow-plug (really a heater plug as a glow plug is something specific to semi-diesels), would eventually join in with the others anyway. I'd be inclined to pop a full set in - especially with a forecast of colder weather to come. | ||
|  6th Nov 2012 11:35am |
| crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698    | Interesting, I did think it was down to the temperature but it happened on saturday when it was a practically tropical 9 degrees. I will mention it to the dealer later on dependent on what they come back with but again another avenue to persue. May just replace them for the hell of it for piece of mind anyway. | ||
|  6th Nov 2012 12:59pm |
| crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698    | Back from the dealer, interesting times ahead I think
|  6th Nov 2012 8:01pm |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048    | I've heard of a few problems with the EGR valves on the TDV8s | ||
|  6th Nov 2012 9:05pm |
 You hit the nail on the head! Warranty company coming out on Monday to approve the work - apparently mine has a problem so its being replaced.... all under warranty. Out of interest how much do these cost (should I not have had a warranty in place). | ||
|  16th Nov 2012 12:28pm |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048    | Don't know the cost but it's a c  | ||
|  16th Nov 2012 12:47pm |
| crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698    | I was guessing that the labour costs would be er quite high! | ||
|  16th Nov 2012 2:46pm |
| crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698    | Egr valves replaced and car it juddering. Took them a week to do which cost me on insuring the courtesy car, fuel and diagnostics fee.   | ||
|  23rd Nov 2012 9:28pm |
| jonlewis Member Since: 06 Nov 2012 Location: UK Posts: 308    | Which dealer did it ?
|  24th Nov 2012 10:56pm |
| crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698    | Hunters Chester wasn't overly impressed but the works done and the judder is no more! | ||
|  24th Nov 2012 11:00pm |
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383    | Let us know if you continue to have no issues, this type of thread is going to be increasingly important as more and more TDV8s change hands and become more affordable. Discovery 4 HSE
|  25th Nov 2012 10:00am |
| Olders Member Since: 17 Mar 2011 Location: Suffolk Posts: 115      | I have a similar juddering when on low throttle inputs and at low speed.  Thought it might have been torque converter. Interestingly, diagnostics showed an intermittently faulty EGR valve, which was causing a greater than normal throttle lag wen pulling off from stationary.
|  26th Nov 2012 8:43am |
| Posting Rules
 t of a job on the TDV8
