![]() | Home > Technical (L322) > Check Brake Pads |
MarkBrand Member Since: 05 Feb 2012 Location: Belfast Posts: 39 ![]() ![]() ![]() |
"Check Brake Pads" I am getting this error message every time I start or stop the engine, been happening for a month now, and I have just changed both front and rear brake pad wires with no effect. Neither one was worn to the point they would have caused a error message on the dash, however this is a new problem to me and I wonder if anyone has any pointers??? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7987 ![]() ![]() ![]() |
I'm not an expert here, never had the issue, but I do understand if the sensor wires have not been fitted back in correctly, you get the message come up..........
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35809 ![]() ![]() |
^^^ +1 ... - .- -.
I will have a check tomorrow for a bad connection in the plugs, apart from that I will just have to get used to the "bong" everytime I stop the engine. |
Most likely a broken sensor wire somewhere in the circuit |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16398 ![]() ![]() ![]() |
Did you buy genuine leads of cheapy ones? There could be your answer... Failing that get it plugged in... Never be too careful with brakes pal... Craig ![]() |
Thanks for Your help.... Problem has cured itself! Hopefully my flickering oil light gets the same idea! |
