![]() | Home > Technical (L322) > Getting heat sooner? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6432 ![]() ![]() |
If I leave the HVAC on automatic, it will take about 10 miles of driving on cold mornings before it starts blowing warm air. I have found, however, that if I start off with one of the selection buttons pressed (screen, footwells) then switch to automatic, I get heat after about a mile.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35872 ![]() ![]() |
never use auto tbh, i like to have it 'my way'.....did get caught by the side vents blowing cold till i realised my centre vent 'scroll' button was set on cold... ... - .- -.
I just use park heat on these colder mornings! -1'c on bangernomics this morn!
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
How do you find the temps without the viscous in place? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Well it seems to warm up a bit quicker but not much else touch wood!
Have you used the hidden menus to see what temps your running and what you were before? I've been temped to do this but concerned with overheating issues. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
I may have used the hidden menu ages ago but not recently.
Having finished my journey to work with footwell and face level buttons pressed and turned off the car, I started my journey home in the same state some 9 hours later. 2 minutes into the ride home (at 30mph) I had lovely warm air coming out of the vents. Even better than the aforementioned button switcheroo. ONly a problem if the screen is misted up, but could try with the screen button pressed too, but aren't I just back to AUTO then ? |
maybe yes, but you are manually in control of the 'auto'..... ![]() Y. O. L. O. . Last edited by stan on 9th Nov 2012 9:29am. Edited 1 time in total |
