![]() | Home > Technical (L322) > L322 4.4 V8 standard battery capacity? |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 ![]() ![]() ![]() |
Hi folks,
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
110Ah is the drain rating - it can supply 110 Amps for an hour, or 55 Amps for 2 hours, etc.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35808 ![]() ![]() |
ideally you should have purchased a bosch type 020 which has 110amh and 920cca... ... - .- -.
Thanks for the reply's gents. Looks like I should have done my research so I knew exactly what battery to ask for. Never mind, ill see how I get on wih or once my alternator is fettled . MY2010 TDV8 Vogue Ipanema Sand
Nice day for it,
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
I would concentrate on the alternator first, when the engine is running with a full load it should still have sufficient output to charge the battery.
Makes good sense.
Have a look online for the pdf version of the L322 Workshop Manual. It has a section on starting and charging. The negative cable goes straight onto the body next to the battery. The positive splits off in one cable to the starter motor and one to the battery by the looks of it. MY 2010 5.0 SC Galway green and sand interior!!
What the diagram doesn't show, and they never do, is the earth connection between the body of the engine and the body of the car, which in turn is connected to the -ve terminal of the battery.
