Home > Technical (L322) > Distressed Newbie!!!!
Beano
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
Hi, Ive just picked up my FFRR an 03 td6 hse. When i picked it up all was well until I decided to have a play with the buttons. The problem now is my front suspension is alot lower and the rear is higher. It was level before this. Ive book it in to be looked at monday morning. But Pleeeeeeeeease could I have some help as what might be the problem.
Cheers
Rich
Post #151757 17th Nov 2012 11:30pm
ollielloyd
United Kingdom 2005 Range Rover Vogue Td6 Java Black
You have a compressor and air bags (don't think there called that) that inflate so probably issue with either of these.
You tried raising or lowering the ride height? Any errors on dash?
Post #151760 17th Nov 2012 11:46pm
Googsy
If you have been pressing the height button repeatedly you may have overheated compressor so leave it for a while disconnect battery leave for 10 mins and reconnect . Then try again . If height button used too much in succession it goes into a safe mode to stop overheating might be the cause. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #151761 17th Nov 2012 11:50pm
Beano
The only thing on display is the usual suspension inactive and 35mph or something. There no light on for the button which operates the hights. Sorry if this is vague. Cheers Olly
Post #151762 17th Nov 2012 11:51pm
ollielloyd
Could of just overheated the compressor. Give it a bit to cool down and try again. What height does it think its at? Also remember all doers need to be closed for it to work.
Post #151768 18th Nov 2012 12:02am
Disconnect the battery for ten mins, then reconnect, start the car turn the steering from full lock left to full lock right (resets some systems) then allow the car to run for 5 mins then raise the car to either normal height or if too high lower it first to park mode... Then raise to normal height... Only when its achieved normal height would i attempt off road height...
Craig Thumbs Up
Post #151769 18th Nov 2012 12:03am
Beano
That maybe one possibilty. Ive also tried with all the doors shut and still have no light on for the height functions just in the same position of the front lower and back still up.
Post #151772 18th Nov 2012 12:08am
ollielloyd
Light on button to change height means auto height adjust is disabled so you don't want that on. You got light in one of the height modes or none lit up?
Post #151773 18th Nov 2012 12:14am
Beano
Theres no lights on at all olly, :roll:
Post #151774 18th Nov 2012 12:16am
You wont get any lights till you do a battery reset!!!
Post #151775 18th Nov 2012 12:17am
Beano
[quote="Cam-Tech-Craig"]You wont get any lights till you do a battery reset!!![/quote]
OK cheers Craig I will try this. As I say Im a complete newbie and still finding my feet in FFRR.
Post #151776 18th Nov 2012 12:20am
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
If you have an Air Suspension Inactive message and no orange lights on the height indicator then the system has logged a fault and won't now try to run the compressor or any part of the suspension system until the fault code is reset. If you have the kit (IID tool, RSW Allcomms etc), it's a 30 second job to read and reset the code; without the kit you can't do it. No amount of disconnecting the battery will help.
When the fault is read you need to consider what it is that has caused the fault to be logged in the first place. If the front suspension struts haven't been replaced, there is a good chance the rubber has perished and they're no longer holding air. If that happens, the compressor is put under considerable stress desperately trying to keep the pressure topped up. It should only run occasionally for short periods under normal use. Replacing the front struts is pretty straightforward, though they cost a good few quid to buy - Island 4x4 was the cheapest I could find and their service was excellent. Replacing the compressor is an OK job, but there is information here about refurbing them if you're paying yourself.
Good luck and welcome to the joys of Solihull reliability! Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #151781 18th Nov 2012 8:00am
