![]() | Home > In Car Electronics (L322) > Range Rovers with DSP, that have lost sound |
andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102 ![]() ![]() ![]() |
BARIS, you come as an angel to me, from 7 months driving without sound, |
Baris Member Since: 06 Mar 2012 Location: North London Posts: 95 ![]() |
First things first. There are a few tests you can do.
Baris, I checked the output voltage (pin 13 bm54 to pin 8 DSP) and seems to be ok (12.7v) the radio module work correctly, also because I have no audio from either nav.
Better off without DSP anyway sounds awful.... |
Thank you Baris , I will check now, bm54 speaker output, can I connect spare speaker into dsp connector?because I can't get the radio connector . alternatively can be fit Harman Kardon logic 7? |
I tried to see if spare speaker can work connected to pin 4- 9+ and/ 5- 10+ on the DSP conector (X18773/26) but no result, AND no audio. I tried with dsp not connected),. I noticed that the radio time during the search does not find anything. in this case can be the radio module the problem.. I would know because just yesterday I took a dsp on ebay, and I would not be useless |
cleughy Member Since: 08 Mar 2012 Location: West Kirby Posts: 361 ![]() ![]() ![]() |
I appear to have lost some of the channels, the sound is full of base and muffled, any chance of this being fixed by you baris?
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 ![]() ![]() ![]() |
Check the plugs that go in to the amp, the pins are most likely corroded due to water ingress or the amp circuitry is damaged |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764 ![]() ![]() ![]() |
Hi Steve,
Andrew, if you have no speaker output from the bm54 it very well must be the bm54. What do you mean by, you can't find radio stations? Can you search for radio and flick through the modes?
Update Baris
Turn the DSP off - sounds better |
I wonder if that will confirm the issue though. If i just turn off the DSP (via the screen options) and see if the radio/sound cuts out again. If not then it's deffo the DSP AMP that's goosed..? Ash
