Home > Maintenance & Mods (L322) > Anyone blanked the EGR valves on a TDV8?
JW911
Just wondering as I've been reading about the mod to the TD6 which improves mpg. Has anyone done it to a 3.6 TDV8? I presume it will run more smoothly and give better mpg, as per the TD6. What are the negatives?
The car is an 07 reg but not sure if it's Euro IV with an EGR light? 2021 3.0 P400 Vogue
2012 4.4 TDV8 Westminster - gone!
2007 3.6 TDV8 Vogue - gone!
2003 4.4 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #152111 19th Nov 2012 6:59pm
I don't think it will be as simple on the TDV8 as it will throw up a EML on the dash
Post #152114 19th Nov 2012 7:13pm
mzplcg
Euro 4 engine. Can't be done easily but no real need to either. They are much more reliable than those fitted to the TDV6.
Post #152124 19th Nov 2012 7:58pm
wackyjim
Scotland 2011 Range Rover SE TDV8 Santorini Black
Mine lasted for all of 3500 miles before going pop!!! Big Cry
Post #152128 19th Nov 2012 8:23pm
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
Mines in being swapped under warranty. Seems to have gone 62,000 before replacement.
Post #152156 19th Nov 2012 10:31pm
Faulty EGR valves are common on the TDV8
I wonder if you could blank them off and fit a resistor to fool the ECU
Post #152162 19th Nov 2012 11:15pm
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
sorry , what would the symptoms be of a failing/failed EGR on a TDv8 2011 4.4 TdV8 Nara Bronze
Post #152268 20th Nov 2012 1:58pm
crookedm
My cars symptoms where juddering upon start up almost as if the whole car shook. I've been told its like your arteries being blocked it gets trickier for it I run without some mild performance issues. Also black smoke is thrown out of it upon acceleration.
Post #152296 20th Nov 2012 3:24pm
