Home > In Car Electronics (L322) > Help with Hybrid Digital Tuner
GTJones
Wales 2002 Range Rover Vogue Td6 Epsom Green
Managed to get my hand on a digital hybrid tuner (Par No 6 966 615 ) i already have an aftermarket DVB-T that uses the existing aerials so i know i can get a signal - fitted the new unit and have two problems.
1. Screen will only display 4:3
2. Can get the unit to scan but after the scan there are no channels displayed?
Unit is set to United Kingdom and PAL so either the unit is U/S or i am doing something wrong.
Any help appreciated.
Gary
Post #152344 20th Nov 2012 7:38pm
mjdronfield
From a quick look on the web, that seems a part number for the hybrid tuner, so unless someones stuck a sticker on an analogue one..........
My hybrid tuner takes quite a while to finish scanning, and I get a differing number of channels found depending on where I am, ie at home or 3 or 4 miles away etc.
Not sure about the 4:3 screen. I know with Navcoder you can change all sorts of settings on the unit.
There is a hidden menu where you may be able to change settings for the video module..........
http://forums.bimmerforums.com/forum/showthread.php?t=1411325
Confused 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #152369 20th Nov 2012 8:40pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
Gary, I suggest you follow the instructions to go into the hidden menu as i don't believe the software numbers of the video module can be changed there and they will tell the truth about its identity. If as you say you can only select 4:3 as a display then there is a worrying chance that you have an original tv tuner in a newer box!
This happened to me a few years ago with a BM54 tuner, it was advertised with a certain part number and as having the aux input but when I fitted it and checked the hidden menus it was clearly an older model in a newer silver box! Fortunately for me the seller was genuine and didn't realise and gave me my money back.
Andy 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #152376 20th Nov 2012 8:58pm
GTJones
Thanks for your replies, i have had a look in the hidden menu and can not find anything regarding screen resolution.
With the exisitng Analogue unit i can select Display settings but not with the Hybrid unit.
Had another go this evening and it looks as if Certain channels are Analogue and others are Digital as when i select certain channels and go back to the menu i can see the EPG (Electronic Programme Guide) for that channel (nothing is shown in the guide) Exclamation
So will have a fiddle with the Country and PAL settings to see if i can get it to work.
Frustrating or what
Post #152453 21st Nov 2012 1:43am
SteveMFr
Site Sponsor
Hi Gary,
The hidden menu does not contain screen format IIRC. You'll need Navcoder and an ibus interface (search for Resler interface). Not expensive. I'd first check the PN on the tuner first, tho. I've posted a list of all tuner PNs and what they are and I believe Andy has as well.
Andy,
Too late now, but Aux in is 'activated' on the BM54 with an appropriate connector. The connector contains resistors (similar to what Apple does with the official iPhone/iPod connectors) that identify it as an authorized BMW Aux in. There are instructions on the net for building this with resistors and appropriate connector pins rather than paying the €50 BMW tax. But w/o this connector plugged into the BM54 no Aux shows anywhere. Rolling Eyes
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #152459 21st Nov 2012 8:35am
GTJones
Hi Steve
Thanks for the reply, the part No is 6-966-615 which is listed as a retrofit Hybrid unit. The Country setting is set to "United Kingdom" although there are also a list of PAL settings in the menu? should i set it to one of these? or will it set to PAL with the setting on "United Kingdom"?
I am using the original aerials, and these work with my aftermarket DVB-T really well. Only changing the unit to get away from using the aftermarket remote control unit but if i can not get it to work will have to try and return the Hybrid unit.
Gary
Post #152529 21st Nov 2012 1:36pm
Pretty Sure you just need United Kingdom no need to mess with PAL settings. I had same issue with a unit in a car I thought was hybrid. Turned out to be analogue only.......
Post #152532 21st Nov 2012 1:41pm
mjdronfield
I'm tempted to think that as you see the EPG, it ought to be a genuine hybrid unit......
Mine works OK with the standard aerials.
To be fair, on the analogue unit, the aerials had connections left and right, as it were, whereas on the hybrid unit, the connections were turned through 90 degrees, so they became front and back if you get me, as orientated in the car.
I never knew whether to plug the one on the original left connection to the front or rear one on the new unit, but just connected them up.
Can't see that this should make a difference to reception, but I'm not an expert........ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #152542 21st Nov 2012 1:56pm
Yes I see then it must be faulty I guess...
Post #152545 21st Nov 2012 1:59pm
Ajay(UK)
SteveMFr wrote:
Andy,
Steve, I agree that the aux input is activated with the correct lead (which I had) but like all of the FFRR BM54 units there was a period when the BMW BM54 also didn't have aux input built into its software so even with the correct lead attached the aux option did not display on the monitor. By entering the hidden menu I was able to read the software version of this "rogue" BMW BM54 tuner which was older than the part number shown on the case. Hence in my instance I had older "guts" in a newer box Shocked
Gary, frrom what you have said about seeing the EPG then you must have a hybrid unit and you can ignore my comments regarding an older unit in a newer box. The aerial connections on the tv tuner shouldn't make any difference but just to be sure you could try reversing them and as also already stated you only need to select UK for the freeview to work, no need to change the pal settings.
Also try and find a nice high spot where you can park up and re-tune, hopefully then you wil pick up some stations and know all is working ok. Thumbs Up
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
Post #152554 21st Nov 2012 2:50pm
