Home > Maintenance & Mods (L322) > Looking for someone to stop the water ingress
cleughy
England 2004 Range Rover Vogue Td6 Santorini Black
Around the north west if possible, anyone know of anyone reputable to do a fix?
Cheers
Steve
Post #153029 23rd Nov 2012 9:59pm
What, where is getting wet? Previously..
Post #153031 23rd Nov 2012 10:11pm
cleughy
Sat nav and amp in the rear
Post #153032 23rd Nov 2012 10:12pm
Yip, common problem. Have you fitted the official water shedder? Previously..
Post #153034 23rd Nov 2012 10:13pm
cleughy
It's got a plastic cover on, but I want to get it fixed if possible
Post #153035 23rd Nov 2012 10:14pm
It's crazy that the landrover fix is just to put a plastic bag over it! I lost my Bluetooth module with the same problem. I never tracked down the source of the leak. Even wondered if it was condensation drips as there must be a bit of heat in there with all the kit, the weather turns cold, etc etc. I wonder if vents in the access hatch would help?? There's an idea....... Previously..
Post #153036 23rd Nov 2012 10:21pm
cleughy
It's more than condensation, there was bad rain last night and plenty of water on the pastic today, sometimes I think I'd be better with a stand alone head unit.
Post #153038 23rd Nov 2012 10:30pm
This will sort it Whistle Whistle
Post #153047 23rd Nov 2012 10:58pm
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
^Not funny. My garage actually recommended that to me. Shocked
DO not under any circumstances just stick a plastic bag over the amp and forget about it.
You must fix it or you'll end up like me with a rust spot on the rear near side body panel which is directly opposite the amp.
Next dry day that comes along will be spent trying to fix it once and for all... although I've tried in the past with no luck.
I read water gets in via holes where the rear bumper is bolted on?
Post #153054 23rd Nov 2012 11:20pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Check the boot seal first, take it off and look for wear holes.
It's pulls off and pushes on, so won't take long to rule out.
Gone - Range Rover Supercharged 2006
Post #153065 24th Nov 2012 1:04am
@ mrd1990
funny you should mention rust on the body panel, I have that in exactly the same place, just back from the door, above the bumper. However, the LHS of my boot is dry as a bone, the water does come in, but on the RHS, and no rust on that panel ?
(If you can't identify location, it is passenger side rear quarter panel, just above the mudflap.) .
Post #153067 24th Nov 2012 2:09am
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
I had the same problem mate, I stripped it all out and got six inch sticky lead flashing and gutter seal and shaped it around the void above the electronics. Havn't got any pics sorry. if you pm your number to me i may be able to explain more clearly. So far touch wood or cloth its been ok. Thumbs Up gone fishin'
Post #153068 24th Nov 2012 9:18am
Dolphinboy
It is probably caused by blocked drain holes, most likely the sunroof. There is oodles of comment here and some pictures, I think the solution was found to be a long rotating wire into the sunroof drain hole or stg. Search should find it. Thumbs Up
Post #153069 24th Nov 2012 9:26am
@cleughy
If you feel like a drive further north I'll sort it for you. Investigated my own thoroughly, not even a drip now.
Post #153082 24th Nov 2012 10:01am
CMJ
2015 Range Rover Autobiography TDV6 Santorini Black
For what it costs replace the boot seal with a new one to be absolutely sure. Fixed 2 different RR's when I have had this problem in the past. I hate water in cars !!
Post #153095 24th Nov 2012 11:52am
