Home > In Car Electronics (L322) > HELP! cd stuck in changer
tony1kenobee
England 2003 Range Rover Autobiography 4.4 V8 Zambezi Silver
hi all , just looking for some help.a cd has become lodged in the cd player (glovebox type)on a 2003 L322 model.does anyone know how to remove the cd player or know anyone who can.im in southampton.any help or pointers would be gratefully accepted.regards in advance
tony
Post #153138 24th Nov 2012 3:12pm
hit it with a screwdriver ... ... - .- -.
Post #153141 24th Nov 2012 3:17pm
GTJones
Wales 2002 Range Rover Vogue Td6 Epsom Green
Re: HELP! cd stuck in changer
tony
Hi Tony
Had the same problem and it is a bit of a pain to get out as the holder is held in with two screws, you have to remove the glove box and also the passenger side end cap before you can get at the screws.
see instruction in the link
http://www.roverupgrades.com/Range_Rover_MP3_Cd_Changer.html
You can then open up the cd changer and rewind the loader arm. I then used some good silicon grease to lubricate the arm.
I left out the two retention screws as it is then so much easier to get it out if it sticks again.
Mine now works a treat.
Hope that helps
Gary
Post #153144 24th Nov 2012 4:15pm
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
had the same on my old car. As Stan says " hit it with a screwdriver " . May sound a bit harsh but it worked for me- it ejected straight away, was fine after that Rolling Eyes Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #153148 24th Nov 2012 4:51pm
Can we just qualify:
"hit it with a screwdriver handle"
just less intense than a small hammer Smile .
Post #153193 24th Nov 2012 8:19pm
tony1kenobee
Thank you all for your input.it seems as if a disc or the holder is stuck half way between the holder and the player.gonna have to take somewhere me thinks. Not that technically minded.ill keep you informed.just a quick question.can I replace the whole unit,if so any recommendations as to what I should replace it with .regards in advance.tony
Post #153202 24th Nov 2012 8:30pm
Unless you want to have a cd player (you probably have the one that only plays audio cds like me) it may be worth looking at the alternatives, e.g. mp3 player (one of those ipod things) that can be run from the screen (do you have a screen or mid unit?) .
Post #153299 25th Nov 2012 2:13am
tony1kenobee
I have a screen with a tv.also iive had a DVD player and a free view box fitted.there is a USB stick port available.can I play my music through the screen with either of these?cheers tony
Post #153334 25th Nov 2012 10:47am
Hi Tony
Yes, I believe the usb port will take/support either flash drives or an external HDD (maybe with a power supply to it) and you can playback digital video files or mp3.
The other way is to make mp3 DVDs and play them back through the DVD / AV interface (although this might not give you stereo, depending on how you are wired up. .
Post #153370 25th Nov 2012 2:59pm
marsie
Yep thats right. Had exactly the same problem with my old car and a sharp tap with a screwdriver handle while pressing the eject button and the magazine ejected no probs. Was fine after that Rolling Eyes Paul
Post #153412 25th Nov 2012 8:42pm
Budgie
If you slide the cover open so you can see the CD cassette, get a torch and shine it down the right hand side of the CD cassette. There's a gap between the CD cassette and the main changer body that will allow you to see which CD is stuck.
Use a small electrical screwdriver and place the blade on the edge of the stuck CD holder and ease it back into the CD cassette, it will go back in by itself once free.
I've had this a couple of times and it seems to be when the I've disconnected the battery.
Post #153458 25th Nov 2012 10:48pm
