Home > Technical (L322) > more electrical problems
muffster
2002 Range Rover Vogue Td6 Java Black
Hello again folks.
I've got yet more bad elcetrical problems, it appears my TD6 really does not like the cold.
Yesterday the car was fine.
This morning. No indication on the dash at first, no radio etc, etc.
I tried the battery reset twice but it didn't work and now the main fan is constantly running.
Even though the car is cold, the fan comes on as soon as I turn the key. I can't find the fuse, 61 according to the handbook so I have disconnecteed the plug in the engine bay.
Any offers on this please.
Thanks.
Post #153118 24th Nov 2012 2:00pm
Sounds like its time for a new battery
Post #153120 24th Nov 2012 2:05pm
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
or alternator, or final stage resistor, just like me! MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #153127 24th Nov 2012 2:36pm
muffster
Ok a quick update.
I left the battery disconnected for a few hours this afternoon.
Now, rev counter working, fuel gauge, radio not displaying german text!
Plugged fan back in and it didn't automatically come on.
Only thing now is the handbrake and abs lights etc are staying lit when the engine is running.
Battery is new and reading 14.18 v when running.
Cheers
Post #153167 24th Nov 2012 5:58pm
Tuts
Abs light should go out if you turn the steering lock to lock after the loss of power 2003 Vogue 4.4 V8 Java Black
Post #153168 24th Nov 2012 6:14pm
mick79
2004 Range Rover Vogue 4.4 V8 Java Black
Second that lock to lock will cancel those out.
Cheers mick Owner of a bottomless pit, Sorry i mean range rover l322.
Post #153399 25th Nov 2012 7:42pm
muffster
That did work today but...
Started it and all was normal except for 'high range selected'.
So, turned it off, and back on. Then, no power steering, no wipers, no clocks working.
It all came back to life as normal after 5 mins driving!!!
No idea what's going on but it's got a mind of it's own.
Post #153404 25th Nov 2012 7:57pm
I would go for a new battery. I just got a new Bosch S5 £113 with 5% cash Bach using quidco. It's a big mother and car starts easier and seem to have less electrical gremlins. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #153413 25th Nov 2012 8:44pm
muffster
Intresting. The battery is quite new but worth looking at.
Cheers
Post #153472 25th Nov 2012 11:22pm
If looking at batteries, dont forget if you order online from euro car parts you can use the discount codes for 25% off even on click and collect.
You can get the bigger 110ah bosch s5 for 99.86 incl
Bargain. There is nothing that can't be fixed with a hammer😜😜
Post #153480 25th Nov 2012 11:50pm
If batttery quite new, worth getting the alternator and circuitry checked out .
Post #153483 25th Nov 2012 11:58pm
Brian GOG
United Kingdom 2002 Range Rover HSE Td6 Epsom Green
Double check the battery has the correct amperage for the vehicle. We've had a few recently where they have been fitted with smaller batteries from the likes of Andrew Pages etc. If you need any advise I'm only in Leeds just give me a call.
Thanks
Brian
Green Oval
0113 2539000
Post #153697 26th Nov 2012 10:18pm
muffster
Great, will do mate.
I got this one from euro parts, cant remember what the a/h is.
But incedently one on the service guys at the dealers said, 'oh yes mate you need a 90a/h for it'.........
Post #153713 26th Nov 2012 10:54pm
simon1233
Battery age is no guarantee of condition. I had to have a 110 amp/hour Bosch battery replaced after 11 months as it was running out of amps. Voltage was OK according to the multimeter, but still had issues with electrics on start up. (Alternator was also new last year and is performing correctly and reconditioning charge with a ctek couldn't save the Bosch battery. Interestingly the original 5 year old battery which was almost entirely discharged when the alternator failed last year is almost 100% restored after being reconditioned with the ctek)
Post #153747 26th Nov 2012 11:53pm
Brian GOG
I don't rate the Bosch ones that highly anymore. They don't seem to have the reserve you get from a genuine or other makes. We are been replacing units with the new AGM Banner batteries with good results.
Brian
Green Oval
Post #153885 27th Nov 2012 6:33pm
