![]() | Home > Off Topic - Other Cars > Jaguar XK-R Sat NAV issues? |
Hi Guys I hope one of you electronic genius's can help me.
You can orient the Map true North or Direction but direction is obviously not the same direction as the car is going! |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
Antenna or wiring between antenna and nav module at fault. |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
There should be a settings mode on it to allow you to see the satellite signal strength I would have thought. Previously..
Will have another fiddle tomorrow - very frustrating had a few Jags with this Nav and never seen this....
Probably similar to the setting the FF uses to re calibrate ====================================
Not being a SAT NAV expert Mick how do you get into that on a FF? |
Its been that long since i have done it Gaz i cannot remember off the top of my head
but its done via the settings menu
Maybe this guy might be able to help you as well Gaz
OK I think I have fixed it by re-cailbrating the system by moving the map until the cursor was sitting in exactly the current location and oriented in the exact right direction. I saved the setting and drove half way round the block and it worked but I thought this may be dead reckonning so I set my home as destination and it all worked tickertee boo.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Thats a nice looking XK-R. |
Arenaitch Member Since: 27 Aug 2012 Location: Twixt Scummers and Skates Posts: 69 ![]() ![]() ![]() |
Traded my XK for the Westie. Must say I do think that the Jag touch screen / sat nav /menu / facilities / controls leaves the RR version in the shade.
You missed this......
All good ![]() |
Yup missed it! But good stuff - and stop putting such tempting objects in front of me!
