Home > Technical (L322) > I Don't Believe it - Flat Battery!!!!
elbitrevnoc
United Kingdom 2006 Range Rover Vogue SE Td6 Buckingham Blue
Well, out the house for the first proper drive this morning and guess what? Flat battery!
Now waiting for LR breakdown to come out. Reading other notes on here it sounds to me like I may need a new battery. The only thing I did differently this morning was to put the pre-heater on - literally for just the 5 minutes it took me to get my shoes on and grab my things. Didn't particularly need it on, but thought I would give it a try.
If the car can't cope with the heater on for 5 minutes than I reckon the battery is shot. Either that or the car's not charging it up. Sad
Post #15290 22nd Mar 2010 9:06am
dan_uk_1984
Sounds like a new battery as you say.
Post #15291 22nd Mar 2010 9:24am
Re: I Don't Believe it - Flat Battery!!!!
I used the pre-heater for 30 minutes every morning throughout the winter and its starts first turn every time. Get a new battery and have the charging circuit checked if the problem persists. The correct battery in good condition can cope with ALL you can throw at it.
Post #15299 22nd Mar 2010 10:31am
People sometimes forget when they take delivery of their car that's it's not been used much so hasn't been getting the charge it needs, and will have been moved about the dealer forecourt all the time, unlocked, locked, power up, power down etc but no distance or time covered.
Why do you think the dealers are always using those boost start machines! Big Cry
This can easily kill a battery off. Discovery 4 HSE
1993 90 Tdi
Post #15306 22nd Mar 2010 12:32pm
elbitrevnoc
Oh well, all sorted!
Good service from LR Assistance and the technician that came out was excellent. All charged up, battery checked over and it's received a clean bill of health. I'm nervous about using the pre-heater again though!
Just the dvd and remote issues to sort now and I'm there!
Post #15379 22nd Mar 2010 10:20pm
Use the pre-heater its great and works fine. If it does not then your battery is not right and it needs replacing.
Post #15394 22nd Mar 2010 11:43pm
jayzee
2006 Range Rover Vogue SE Supercharged Java Black
Take it for a long drive. Do this often if you only normally travel locally, else get yourself a CTEK to keep the battery topped upand in good condition/ Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD!
Post #15400 23rd Mar 2010 12:13am
elbitrevnoc
Thanks. I normally do 150 miles a day. Did that yesterday, so we'll see how I get on.
Post #15405 23rd Mar 2010 8:10am
Wow that's a long commute! Would not fancy your fuel bill just for getting to work Big Cry
Post #15409 23rd Mar 2010 8:52am
That's the same as my commute, difference being I don't have to do it every day!
With regards to the rear seat ent' remote control. The remote is inactive when the front screen is showing the 2 rear sides selection panels, as it means the driver is controlling what the rear screens can see and what they can hear.
once this is cancelled out the remote controls the rear screens, using the slide switch on the rear of the remote you select which screen to control. I had the same issue with mine and thought it was foooked. Whistle Discovery 4 HSE
1993 90 Tdi
Post #15422 23rd Mar 2010 10:49am
elbitrevnoc
Cracked it! Thanks, RRUK you are the truly the master, the Obi Wan of remotes. This has been driving me nuts! Bow down Bow down Bow down Bow down
The L/H side red light on the remote is still permanently lit though and I think this is why the batteries were dead. How do you actually turn the remote off (i.e., put the red light out)? I've tried putting the switch in the middle and pressing in the arrowed direction, but light stays stubbornly on. Also, the R/H side doesn't seem to light at all, but I can control the screen ok.
BTW, like you, I don't do the drive every day, but at least a couple of times a week. Nice car to do it in though!
Post #15463 23rd Mar 2010 4:14pm
I'm not sure about the red light, maybe the remote is defective after all and needs replacing? I can't check my own cos the car is down in Solihull being trashed no doubt by the grease monkey technicians.... Discovery 4 HSE
1993 90 Tdi
Post #15470 23rd Mar 2010 4:50pm
jayzee
That's what I said on the other thread! Big Cry
I'll get me coat now! Wink
Seriously, I thought mine was fooked too, then bothered to read the manual - all became clear Whistle
Smile Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD!
Post #15480 23rd Mar 2010 7:40pm
As they say, it's all in the delivery! Laughing Discovery 4 HSE
1993 90 Tdi
Post #15487 23rd Mar 2010 8:45pm
jayzee
Hmm, I may need to refine my technique Laughing Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD!
Post #15504 23rd Mar 2010 11:17pm
