![]() | Home > Technical (L322) > Live 12v socket? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8768 ![]() ![]() ![]() |
Not going to say RTFM as im pretty sure it says in there re charging, but a good run out should charge it sufficiently to make the FBH run properly, imho i would always charge directly on the battery, though its not strictly neccessary according to those in the know on here. Are you sure the 12v in the boot isnt permanently live, it is in mine 2008?
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 ![]() ![]() ![]() |
Im with northenmonkejones, i would personally just charge on the battery. If you have a good charger, like a CTEK than you don't have to disconnect the terminals.
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 793 ![]() ![]() ![]() |
Not being lazy. I have tested all the 12v sockets I can locate and none of them I can find remain live once it's locked. Just surprised that the MY07 has a useful live 12v socket in the boot but the new improved MY11 doesn't!
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 ![]() ![]() ![]() |
It's possible the car is shutting down due to low voltage, including shutting off the cigarette sockets that are normally live. Wouldn't surprise me if the later l322's had a low voltage cut off for the normally permanent live sockets. I can imagine some people plugging in a 12v mini fridge and leaving them switched on all day..
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35809 ![]() ![]() |
frustratingly on my 2005 , the centre console socket was opposite and always live so i couldn't leave my camera/recorder plugged knowing it would switch off automatically.. ... - .- -.
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
No permanently live sockets on mine.
Thanks Ian. I will leave the FBH diagnosis to LR then. MY23 D350 HSE
