Home > Maintenance & Mods (L322) > Broken seat plastic side trim
mjdronfield
As this seems to happen quite alot, I knew I was on borrowed time, and 9 years of use has finally broken the drivers seat trim, the one at the side, enclosing the electric seat switches.......
Its only broken around the screw head at the back where it fastens onto the rear of the seat.
Has anyone managed to fix it ?
I'm thinking perhaps drilling a hole in the top of a metal tyre valve cover, and using that as a cup to hold the screw head and stop the trim moving off the head.......
Does anyone know what screw thread the torx bolt is, as if it were slightly longer..........
Any ideas ?
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #154863 2nd Dec 2012 10:55am
can the plastic be glued back together with strong adeshive, i use carpenters mitre fix for quite a lot of repairs around the place and it sticks well, glue and activator pack available from screwfix, b and q, magnet, howdens and most hardwarey type places.
have a look in the screwfix catalogue for a replacement bolt, they do all sorts, have not seen it but would guess that it would probably be available in a variety of lengths, you will have to buy a few though.
how about something like this:
http://www.screwfix.com/p/bzp-head-socket-...f-50/60767 There is nothing that can't be fixed with a hammer😜😜
Post #154867 2nd Dec 2012 11:29am
mjdronfield
Cheers mate.
The plastic has literally broken around the screw head. Its pretty much acting like the screw isn't in.
Don't think its best suited to glue holding, as there isn't much surface area.
Will try and find out what the bolt thread is, and I've a feeling a longer bolt with a slightly bigger head may hold it.
Thanks for the screwfix link. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #154870 2nd Dec 2012 11:45am
loadza different sizes and head shapes available, I'm sure with a bit of bodging and prodding it can be forced to stay in position. There is nothing that can't be fixed with a hammer😜😜
Post #154872 2nd Dec 2012 11:48am
daveo
if you can get the trim of, great.. I repaired both my friends by gluing a washer behind the trim with some epoxy, you can build it up and bet plenty on as it is all hidden. V8 facelift Range Rover Autobiography 22" wheels.
Post #154879 2nd Dec 2012 2:07pm
mjdronfield
Ah..........good idea.
I have a hot melt gun. That may do the trick with a washer, provided I don't get the end near the viewable trim.
I'm guessing with bolt sizes at the mo. The online microcat says M4 x 12, but I'm not convinced.
Firing up the old laptop with Microcat installed as I type..........
Cheers 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #154887 2nd Dec 2012 2:48pm
daveo
I think it was a m5, remember to key the area well , after they dried we painted the front black to match the trim and it was as good as new, in fact better as you don't have to worry about the bolt pulling through.. V8 facelift Range Rover Autobiography 22" wheels.
Post #154888 2nd Dec 2012 2:59pm
mjdronfield
Thanks Dave.
According to my Microcat, its M5 x 6.0 mm.
Do the other 4 clips just press down with a flat blade to release do you remember ?
RAVE just says release 4 clips...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #154889 2nd Dec 2012 3:14pm
daveo
its one of those trims that when you get it off it all comes clear, you don't need a screwdriver as you can do it with your finger, just take your time and don't force it, start with the clip at the front.. V8 facelift Range Rover Autobiography 22" wheels.
Post #154900 2nd Dec 2012 4:49pm
