![]() | Home > Technical (L322) > Battery Flat and car down to bump stops. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3942 ![]() ![]() ![]() |
Car parked on drive in freezing cold conditions for a few days ended up down on bump stops and wouldn't start - flat battery (new Bosch).
Hi Geoff,
Yep, this is a new battery because the old one had the same symptoms, wouldn't start on cold mornings never mind firing up the FBH.
Actually there is one thing that often does not got to sleep and that is the BT module as my phone just stays paired with the car and I need to turn it off on the phone to stop it happening. Geoff |
Your FFRR has what is known as 'Parasitic Drain'. This clip explains how to check it out |
Without starting the parasitic drain investigation I have noted that the rear HEVAC fan doesn't work and regardless of setting it just trickles warm air - is this a clue? is there a separate FSR for the rear if so can it simply be disconnected. Obviously interested to hear if anyone else's behaves similarly or differently. Geoff |
I'm just going to bump this in case anyone can help - |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
Hi Geoff
Thanks Simon,
Thanks, mines the same as yours, glad i didn't start tearing things to pieces.
