Home > Technical (L322) > Coolant leak
Page 1 of 3 123>
SparkyPhil
England 2005 Range Rover Vogue 4.4 V8 Adriatic Blue
Coolant leak
Well I pulled the car out of the garage this morning and noticed a patch of oil under the car, on investigating the oil I came to the conclusion it was gearbox oil(red and thin). I got under the car and found a slight drip around the bellhousing but nothing major. I took the car out for a drive about and all seemed as it should. I have now googled the problem and thought it is the oil cooler pipes to the gearbox, so back under the car I go for further investigation. Pipes seem ok there is no oil anywhere not even a micro droplet, so does anyone know where it may be coming from? By the way it is the 5 speed zf box.
Cheers
Phil
Post #154712 1st Dec 2012 3:52pm
could it be coolant? the gearbox oil should be a honey color if new and prob black if it hasnt been change in its life. the V8 use either red/pink/orange coolant or blue/green. if its by the bell housing could be one of the hose's at the back of the engine running down. i had a similar issue with mine. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #154735 1st Dec 2012 6:36pm
steptoe
Rob2529 wrote:
could it be coolant? .
Could well be. Coolant doesn't evaporate and leaves a patch on the floor which looks like oil Thumbs Up
Post #154751 1st Dec 2012 8:00pm
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
Coolant manifold gaskets leaking. I've just replaced mine for the same reason. MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #154753 1st Dec 2012 8:08pm
SparkyPhil
Just been out to check coolant and I don't seem to have lost any but it was still slightly warm. It is red/pink in colour but by dipping my finger in the header tank I couldn't really tell if the texture was the same also I have cardboard under the car and the coolant/oil was sitting on top and had not been absorbed, which makes me think it is oil.
Phil
Post #154756 1st Dec 2012 8:17pm
Do the taste test, if it's sweet and sticky it is antifreeze Thumbs Up
Post #154757 1st Dec 2012 8:20pm
mjdronfield
Just about to say, have a taste of it.
You can't fool the tastebuds !!
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #154760 1st Dec 2012 8:35pm
SparkyPhil
Well thanks for the replies, I have placed a washing up bowl under the car so will be tasting whatever has fallen into the bowl tomorrow, but it is totally dry at the moment.
Phil
Post #154765 1st Dec 2012 8:47pm
SparkyPhil
Well under the car this morning to taste whatever was in the bowl and it was empty Thumbs Up I think I will let it develop and see what happens.
Phil
Post #154856 2nd Dec 2012 10:24am
Have you had the air con on ? Could just be water drips from that (slightly contaminated). This drip is perfectly normal!
Does sound like coolant from manifold gaskets / PCV hoses etc though at the back of the engine. If it was oil/ATF it would drip everytime. .
Post #154873 2nd Dec 2012 11:54am
SparkyPhil
Quick update: It seems that a coolant hose which is something to do with the lpg system, is actually a rubber gas hose and with warm coolant being passed through it has gone brittle and started to crack, there is also a slight leak on the thermostat housing, I am a bit p****d that the wrong hose was fitted in the first place but it has been rectified now. I also had a level 2 service done a few weeks ago and none of this was noticed? Thanks for all the replies.
Phil
Post #155363 4th Dec 2012 7:47pm
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
glad you sorted Very Happy
Post #155371 4th Dec 2012 8:16pm
woodchopper23
You should get the rave and if you have the tjne and inclination, you can do your own maintainance then you know its dine propperly . Save your self 90 pounds plus per hour also . MY2010 TDV8 Vogue Ipanema Sand
Post #155674 6th Dec 2012 9:40am
SparkyPhil
I have still got a water leak Big Cry I am begining to think its the coolant manifold as other people have suggested,( it only seems to leak when cold).I will be doing all my own routine servicing from now on, but at the moment I am off work with a bad back and trying to mess with the car is a no no.
Phil
Post #156167 8th Dec 2012 7:31pm
SparkyPhil
Update:
I still have my leak. It has been in the garage 3 times and still not sorted Big Cry so I am now a bit more mobile I decided to investigate it my self and low and behold after about 10 minutes messing about I was convinced I had spotted it, so 8am christmas eve I was back in the garage for another look and yes it was leaking from from where I thought (T Piece to lpg vaporizer) so now i just need to get some hose, 2 T pieces and some coolant and do it myself.
Phil
Post #160034 26th Dec 2012 11:53am
Page 1 of 3 123>
