Home > General > 18" and 20" Wheel mix?
dan_uk_1984
I’m going to embarrass myself here…. Are 18” wheels + tyres the same size as 20” wheels plus tyres? I.e. do they have the same overall diameter? I thought the 20" just has a thinner tyre and the rolling distance is the same otherwise the speedo would be different between the Vogue and the HSE for example with the different spec wheels?
I’m picking up some 20” wheels at the weekend, but only a set of 4, could I keep my spare 18” as a spare?
With odd sized tyres I imagine the suspension will have a “plausibility scenario” issue as well as the axle diff would overheat if used for more than a few miles.
I never carry a spare with me, due to the LPG tank anyway and I’m usually close to home. But it’s sods law if I don’t have one I’ll get a flat!
Dan
Post #15569 24th Mar 2010 3:45pm
jayzee
2006 Range Rover Vogue SE Supercharged Java Black
You will have the same rolling radius, else your speedo would be out. Keeping the 18 as a spare would be fine. Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD!
Post #15570 24th Mar 2010 3:50pm
dan_uk_1984
Yay.
Post #15571 24th Mar 2010 3:51pm
sleepezy
About half of the way down is an overall circumferance calculator/comparison for current wheel/tyre vs new wheel/tyre:
http://www.carbibles.com/tyre_bible_pg4.html
I would presume as long as they're not too far out you're OK for a short period - otherwise your diff will work overtime!
Post #15574 24th Mar 2010 4:05pm
Yep, all fine.
But, you wouldn't want to have the 18" tyre on for long as the sidewall depth and flexibility are so different, I've never tried it but it could potentially affect handling or safety.
But, these days, who uses a psare for long periods of time? Discovery 4 HSE
1993 90 Tdi
Post #15575 24th Mar 2010 4:05pm
dan_uk_1984
Thanks for that, all seems fine:
Post #15578 24th Mar 2010 4:22pm
Andy
Re: 18" and 20" Wheel mix?
Dan
Thats what I've had to do. I am looking for a 5th wheel in a 20" though. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #15581 24th Mar 2010 5:15pm
As already stated as long as the wheel/tyre combinations are the stock sizes 18/19/20 can be mixed as far as rolling radius is concerned. Thumbs Up
Post #15583 24th Mar 2010 6:12pm
