Home > Technical (L322) > Strange Noise
Page 2 of 3 <123>
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
same 'problem' here.
i sounds like it comes form the passenger side front bulk head.
did not hear it over the sumer/autumn. but more frequently when outside temp is about 5ish or below
i put it down to the parking heater. as it is in the location where the noise is coming form and it was used in the diesels as they they run so cold.. 2011 4.4 TdV8 Nara Bronze
Post #155741 6th Dec 2012 1:46pm
where are you in the UK?? It may help if someone else who knows the FBH sounds could listen?
Also try the timed climate and see if its the noise and if not at least it will clean the FBH out a bit Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #155747 6th Dec 2012 1:55pm
jonlewis
2007 Range Rover Vogue TDV8 Buckingham Blue
Well autochanger rule out, had the noise last night when i got in the car at a cold and wet station.
Will do the 'passenger' perception test over the weekend.
I am in Bury, just north of Manchester if any knowledgeable members are nearby. 2011 Stornaway Grey 5.0SC Autobiography
Post #155932 7th Dec 2012 9:36am
benjj
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Have you checked the passenger side mirror?
It could be a sticky/failing motor on that. Remember it also dips when you select reverse so does that correspond with the noise?
Post #155941 7th Dec 2012 10:19am
jonlewis
Almost captured the noise today, but by the time I had my phone ready it had stopped. From the outside it sounds very dodgy. Confused 2011 Stornaway Grey 5.0SC Autobiography
Post #156019 7th Dec 2012 6:55pm
jonlewis
Stange Sound - Update
Managed to get a recording of the noise. This is from outside, and while a bit constant on the recording is normally a little more random
https://dl.dropbox.com/u/2916473/Range%20Rover%20Sound.m4a 2011 Stornaway Grey 5.0SC Autobiography
Post #156119 8th Dec 2012 1:41pm
sounds like a pulley? where in the engine bay is it coming from? There is nothing that can't be fixed with a hammer😜😜
Post #156122 8th Dec 2012 1:51pm
jonlewis
Not sure yet. Only occurred to me afterwards to open the bonnet, but by that time the noise had stopped.
Next time, I will get it Very Happy 2011 Stornaway Grey 5.0SC Autobiography
Post #156123 8th Dec 2012 1:57pm
mpirie
Now that I've heard it, I have that noise too. Big Cry
Post #156124 8th Dec 2012 2:02pm
jonlewis
Underneath the battery area...... Happened again as soon as I got in........got the bonnet up just in time. 2011 Stornaway Grey 5.0SC Autobiography
Post #156125 8th Dec 2012 2:03pm
Sounds like the FBH. My one makes the same noise. Only hear it at this time of the year when it switches itself on. Never a squeak or groan for the warmer months. Previously..
Post #156126 8th Dec 2012 2:05pm
And... You do know the FBH is located under the battery? Thumbs Up Previously..
Post #156127 8th Dec 2012 2:08pm
jonlewis
When i switch it on manually, it sounds nothing like that though......... 2011 Stornaway Grey 5.0SC Autobiography
Post #156131 8th Dec 2012 2:19pm
jonlewis
Done another check by switching the FBH on with the bonnet open. Not the same sound. The FBH is a constant low level noise which is not overly intrusive. The other noise is actually quite invasive into the cabin and sounds alot louder
What, if any, pulleys or ancillaries are on that side of the engine ? 2011 Stornaway Grey 5.0SC Autobiography
Post #156135 8th Dec 2012 2:54pm
Thelord67
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
I am staggered, I have the exact same noise! I look forward to it being diagnosed...
Thumbs Up Thumbs Up Sheep Thumbs Up Thumbs Up Range rover tdv8 56. Vogue
Sand and jet
Upgraded the Bluetooth and digital tv
Post #156137 8th Dec 2012 3:29pm
Page 2 of 3 <123>
